Old 11-25-2019, 10:35 AM
1969GiPper 1969GiPper is offline
On older vehicles it’s not uncommon for a wire in the harness to break inside the rubber conduit between the hinge pillar and the door. Over the years the wires in the conduit are being bent back and forth each time the door is opened and closed. Eventually one wire will break causing something inside the door not to work. Often when repairing that wire you will find other wires on the verge of breaking for the same reason. Not saying this is your problem but it is something to keep in mind.
The Following User Says Thank You to 1969GiPper For This Useful Post:
