Old 12-06-2019, 12:49 PM
Daubert20's Avatar
Daubert20 Daubert20 is offline
Default Parts Washer - Looking for Solvent Recommendations
We have a new/never used Northern 20gallon parts washer (12 gallon solvent capacity). I'm looking for some recommendations for a good solvent to use. I believe it needs to be non-corrosive. Any help you may have would be greatly appreciated!
www.gtopa.org
GTO Association of Pennsylvania
Webmaster
Old 12-06-2019, 01:27 PM
lemansboy70's Avatar
lemansboy70 lemansboy70 is offline
PB Blaster makes a good solvent. It is not mineral spirit based. Doesn't leave a residue and can be use on some plastics even. Sells for about $85 for five gallons at Napa.
30+ Years with NAPA. Happy to help with any auto parts questions.
Old 12-06-2019, 02:32 PM
craigs69's Avatar
craigs69 craigs69 is offline
I just bought 5 gallons of parts washer solvent at Tractor Supply last week for around $58. I haven't used it yet, so I can't say how well it works.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
Old 12-06-2019, 03:01 PM
I normally purchase mineral spirit based solvent from Rural King. It seems to last longer than mineral spirit replacements.
Dr. Thomas Sowell
Old 12-06-2019, 05:47 PM
geeteeohguy's Avatar
My machinist uses Cascade dishwashing soap in his. No suds, cleans well. Simply soap and water.
Jeff
Old 12-06-2019, 05:48 PM
Misread this thread.....I thought you had one of the heated steam spray wash cabinets, not a solvent tank. Please disregard!
Jeff
Old 12-06-2019, 06:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
140 Solvent is what we use. I don't like mineral spirits because of the smell... Thing you have to watch out for , if the unit has a plastic pump (cheapie) the solvent distorts the plastic and the pump stops working in short order.
Go fast, see Elvis!
Old 12-06-2019, 09:24 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Paint thinner.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 12-06-2019, 10:50 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is online now
Stoddard solvent add some auto trans fluid to soften the harshness.
Old 12-06-2019, 10:58 PM
Cardo's Avatar
Cardo Cardo is offline
I've used the Tractor Supply solvent. Works well, just make sure to keep the lid closed on the washer or it will evaporate.
Old 12-07-2019, 12:14 AM
SRR's Avatar
SRR SRR is offline
https://www.northerntool.com/shop/to...rch=47479-1651
Is this it? Says water based solvents only.
― Calvin Coolidge
Old 12-07-2019, 08:28 PM
necdb3's Avatar
necdb3 necdb3 is offline
I'm going to try "purple stuff" in the same cleaner diluted 15-1 and see what happens. I can always add more if it's not strong enough. Probably won't try it for about a month or so as I won't need it till then. I'll let you know how it works out.
Old 12-07-2019, 10:44 PM
I bought one of those a few years ago... Got tired of fooling around with the water based degreasers and bought a solvent rated pump from Amazon .. modified it to fit and been using it that way since.
I use odorless mineral spirits but wondered if there was something better myself.
Sent from my moto g(6) play using Tapatalk
Old 12-09-2019, 12:50 PM
Daubert20's Avatar
Thanks everyone. Looking at the washer closer it does specify only water based. We had a decent (warmer) day here in PA yesterday so I ended up washing my M20 parts out in the driveway with good old gas. The parts washer will be nice to have in place though long term.
www.gtopa.org
Webmaster
Old 12-09-2019, 03:59 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I used the stuff from Tractor Supply. It works pretty decently. Its reasonably priced compared to other stuff. When I was doing research it seemed like the cheap/safe stuff worked well if heated. Or you can use something with a much more dangerous flash point that works fine at room temp. Diesel seemed like a decent option if you didn't mind your garage smelling like a truck stop.
In retrospect I wish I had spent more money up front and bought a unit that heated the fluid. I didn't realize it before purchase.
