Old 12-13-2019, 02:51 AM
pont406's Avatar
pont406 pont406 is offline
Tom S, I know where this M/T aluminum block and one off heads with intake and exhaust ports on same side is, and maybe available too
Name:	61 mickey exp.jpg
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 12-13-2019, 04:23 AM
dataway's Avatar
dataway dataway is offline
I've got three of them in my shed.
My imaginary shed
Old 12-13-2019, 11:20 AM
tom s tom s is offline
I think Herb has his block sold and im trying to help him sell the heads.His block does not have the joined lifter bores or the grooves for the hemi heads.His is like the one I built some years ago.Tom
Old 12-13-2019, 11:37 AM
Jack and all,there is NO machined holes in these blocks.The challenge is to get them machined first.I have not seen any M/T heads avil for a price I would be remotely interested in.These blocks have been around for years,there have been guys trying to buy them.The guy that had them bought them some years ago.There has been some posts on another board about them.I think Steve knew these blocks were around but might not have known they were hemi blocks.I just turned 75 a couple days ago,I have 2 RA V projects going right now along with dealing with these.Don Keefe wants to do a article for Poncho Perfection.Im going to get them out of the crates today and will post more pics.The owner brought them to me because he knew I am crazy enough to try to get them built in some form but Hemi is not in my thoughts.If I build them they will go in my cars.Tom
Old 12-13-2019, 11:48 AM
pont406's Avatar
Talking
Oh Ok He texted me the other day about if I knew of anyone looking for these parts, pretty neat stuff! I should have figured you knew about them LOL
Old 12-13-2019, 01:04 PM
Mike Davis's Avatar
Tom, any clue how many of these blocks we're cast?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 12-13-2019, 01:34 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Name:	Pontiac 389 aluminum block - Mickey Thompson (1).jpg
Old 12-13-2019, 01:49 PM
Mike,any pics of the valley?Tom
Old 12-13-2019, 01:56 PM
OK,bare alu bore 3.75,bare main bore 2.90,inside sleeve(rusty)3.95,outside sleeve 4.255,inside main web at bolt hole 1.15,outside main bolt hole 1.019.
ID:	526680   Click image for larger version
ID:	526681   Click image for larger version
ID:	526682   Click image for larger version
Old 12-13-2019, 02:45 PM
242177P's Avatar
242177P 242177P is offline
If you ask me, this block almost screams OHC.
(we're pretty good at spending Tom's money )
But seriously, thanks for sharing.
Old 12-13-2019, 03:04 PM
Stuart's Avatar
Stuart Stuart is offline
Looks like those things are going to keep your machinist busy.
Old 12-13-2019, 03:15 PM
Lee's Avatar
Lee Lee is offline
Tom, have you ever done a DNA test? I'm hoping you may be my long lost uncle :-)
AMAZINGLY cool stuff, thank you for sharing with us!
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 12-13-2019, 03:18 PM
Interesting that the block has cam bores except for the front one?
Who are you having do the machine work?
Old 12-13-2019, 03:23 PM
sdbob sdbob is online now
Does the machinist have blueprints to locate and layout the drilled holes and the distributor hole? Or is there another method that is used on current blocks? I know there must be but just wondering the process.
Old 12-13-2019, 03:40 PM
Region Warrior's Avatar
WOW...never say never.
Be awesome if any early aluminum d-port heads where made and found for said build...
Old 12-13-2019, 04:10 PM
MikeNoun's Avatar
Here you go Tom.
Name:	Pontiac 389 aluminum block - Mickey Thompson (3).jpg
ID:	526689   Click image for larger version
Name:	Pontiac 389 aluminum block - Mickey Thompson (2).jpg
ID:	526690   Click image for larger version
Name:	Pontiac 389 aluminum block - Mickey Thompson (8).jpg
Old 12-13-2019, 04:11 PM
MikeNoun's Avatar
Another one of the backside.
Name:	Pontiac 389 aluminum block - Mickey Thompson (6).jpg
  #38
Old 12-13-2019, 04:18 PM
David Jones's Avatar
Good stuff Tom.
  #39
Old 12-13-2019, 05:03 PM
Thanks Mike,that is like the first one I had,no joined lifter bores.
  #40
Old 12-13-2019, 05:39 PM
Tom,
Mr Mike Noun's photos make clear it's only fair&wise to have those Blocks fully photographed, and then machined for the obvious & needed surfaces.
Keep the Crates.
