Old 12-11-2019, 10:14 AM
77 Canamman's Avatar
Thumbs down
Originally Posted by burd View Post
I’ve got a few pics coming of originals. I won’t post crap taken from the internet..
These were made with the help of a member here..NOT from google
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #5442
Old 12-11-2019, 10:17 AM
Exclamation
Oh some tool factory will say these are pulled from Google..cue the tROLL
  #5443
Old 12-11-2019, 05:31 PM
burd burd is offline
He wants to see original tags on orig cars not tags people make. I know, we spoke on the phone.
  #5444
Old 12-11-2019, 05:53 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
If you look at the '73 SD picture I posted, it has an ink stamped pick code.
So long, farewell.
  #5445
Old 12-11-2019, 06:02 PM
I know 4 people with 74’s. Let’s see if their OG decals are there. Are all 1974 decals the same? One is a 74 COPO cop car , Nova. Z28 motor. Other 3 are Pontiac’s. Let’s see.
I'd like to see the Pontiac ones, as long as they're Firebird units.
So long, farewell.
  #5446
Old 12-11-2019, 06:59 PM
Thumbs down
Good for you..
The artwork came from a NOS pump. Go back to selling your overpriced nOS crap.
  #5447
Old 12-11-2019, 10:10 PM
gilg gilg is offline
I found in other Forum picture of 1974 Camaro Z28 with the same Decal Style as the the Low Miles 1973 Super Duty from another forum and both decals look the same
For 1974 Z28 "BK" is the correct P/S code and is stamped on ink over the decal
For 1973 SD "HG" is the correct P/S code and is stamped on ink over the decal
the correct code for P/S pump its located on BOX 32 in the Build Sheet for both Models
My conclusion is probably this decal is the same for 1973 and 1974 F-body and the codes changes was made on Ink stamp
i posted the pics what i found and also my own version of the decal.
Name:	Full page photo (2).jpg
ID:	526472   Click image for larger version
Name:	1973 TRANS AM 7.5 AUTO NW 01774 MILES RED (14).jpg
ID:	526473   Click image for larger version
Name:	Wednesday, December 11, 2019.jpg
  #5448
Old 12-12-2019, 12:56 AM
Transamric's Avatar
File under FWIW. Several Build sheets I have for both Chev & Pontiac from '71 to '73 show P/S pump code BK in Box 32. of course the mounting brackets and pulleys are way different with Chev engines, but not sure that there was any difference with the pumps themselves.
HOWEVER, one '73 Build Sheet I have for 2U87Y3N120xxx (built 2/28) has code HG in Box 32. Odd duck??
  #5449
Old 12-12-2019, 01:00 AM
Transamric's Avatar
Addition to the above. '73 Z28 1Q87T3N172756 was back to a BK pump code even though built after (5/23) the Formula 455 I just showed.
  #5450
Old 12-12-2019, 03:54 PM
Funny. Every 1972 Pontiac build sheet I have shows HG XD (pump/pulley) in box 32.
So long, farewell.
  #5451
Old 12-12-2019, 06:54 PM
FOR 1973 & 1974 SD-455
BOX 32 = P/S PUMP & PULLEY = HG XD
HG= GM Gr 6.605 HG 7811290 POWER STEERING PUMP
XD= GM Gr 6.655 XD 481042 PULLEY POWER STEERING PUMP
1 ROW 6.25" DIAMETER CASTING 481042XD - (GM SERVICE 493243)
  #5452
Old 12-12-2019, 08:14 PM
All the 71-72-73-74 TA/Bird Buildsheets i have show HG - XD
Does not mean they all used the same exact style decal for all those years though.
I don't know anything about those decals, at all.
70 TA/Bird was HF - JK
And for the record - i Always Pried against the Reservoir with a wooden hammer handle to tighten the belt.
  #5453
Old 12-13-2019, 08:25 AM
Lightbulb
With a pry bar, you leverage against this tab to make belt adjustments. It is very easy to damage those pumps.
  #5454
Old 12-13-2019, 11:40 AM
Better late , than never. Will try to remember about that tab.
Thanks 77
  #5455
Old 12-13-2019, 05:08 PM
Transamric's Avatar
Another FWIW. Here's a scan of the '73 Z28 I referenced with a BK pump code. I agree that the vast majority '72-73 show HG. That's why I asked if this Z28 is an oddball build with a BK pump.
Name:	73 Z28 Build Sheet.jpg
  #5456
Old 12-13-2019, 08:01 PM
For 1971 to 1974 Z28 Power steering pump part number is different than for Trans Am the number is : GM 7813397 = "BK"
For 1971 to 1974 Trans Am Power steering pump part number is : GM 7811290 = "HG"
Attach another Build Sheet for 1972 Z28 with "BK" P/S Pump
Name:	NW 1972 Z28.jpg
1966 GTO - 1969 T/A Auto - 1974 T/A SD455 - 1977 T/A SE Y82 Auto T-Tops
1978 T/A Black W72 WS6 T-Tops NW - 1978 T/A Black W72 WS6 T-Tops VN
1979 T/A 10th Y89 4SP NW - 1979 T/A 10th Y89 4SP VN
1980 T/A Pace Car Y85 - 1980 T/A Turbo Y84 T-Tops - 1981 T/A SE Y84 Auto 5.0
  #5457
Old 12-13-2019, 09:20 PM
An interesting thing about the camaro sheets: U76 - W/S Antenna
Evidently the windshield antenna wasn't standard on them?
(knew Firebirds had them standard, figured it was a F-body thing)
  #5458
Old 12-14-2019, 08:52 AM
1974 SD-455 NICE!!!!!!!
  #5459
Old 01-09-2020, 12:01 PM
Red 73 SuperDuty 4 Speed Trans Am for sale at Trans Am Specialties .
Not sure of price, but evidently around the 150k mark.
Not concourse , but appears to be a pretty good car and #s matching drivetrain.
Could be a good opportunity if someone is looking for a 73 4 Speed car
Link to car -
https://transamflorida.com/1013.htm
  #5460
Old 01-09-2020, 01:00 PM
Norwood's Avatar
Norwood Norwood is offline
At 150 I would expect correct master and exhaust. But that’s just me.
