Old 01-22-2020, 03:08 PM
455abody 455abody is offline
Default vacumme diagrams
Does anyone know where to get a good engine diagram? I would like to see where the factory installed the vacumme lines. I need for a 70. Thanks Brian
Old 01-22-2020, 04:11 PM
Stuart's Avatar
Stuart Stuart is offline
You should be more specific...is it for a Bonneville, GTO, Firebird, etc. Also, which engine, plus any options like air conditioning or cruise control that may affect the vacuum line requirements.
If you have the factory shop manual for your car, the information should be in there someplace.
Old 01-22-2020, 04:19 PM
Yes 70 Gto with air conditioning no cruise automatic.
Old 01-22-2020, 04:43 PM
Kenth's Avatar
Kenth Kenth is offline
You will find most everything you want to know about your GTO in the 1970 Pontiac Service Manual.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-23-2020, 02:16 PM
track73 track73 is offline
If there is a library in your town most have Haynes manuals for particular cars. I'm lucky our county library has Mitchell on Demand.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
