On other engines that remains to be seen. On the Pontiac, it depends on what brand or style lifter 68hotbird finds that works with the oil band location on a Pontiac, or possibly the lifter bore oiling mod needs to be done to open up the choices. Seems he has the spider and dog bones figured out and those are usually pretty cheap to buy. Pretty slick if it all works out. |
Neat.
I was wondering why no one was going down this path given all the issues with retrofit roller lifters these days!
Triple Black 1971 GTO |
Yeah. I daily drive. So I'd go for factory parts over third party even if it wasn't cheaper. I know they are engineered for long term durability.
Sam
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
Nice job 68HB ! Like others, I was wondering about this concept. My Tag line is appropriate.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I have to ask if the factory lifters will hold up to a performance cam and spring pressures?Tom
I have a brand new 502 GM crate roller engine here that's getting an aftermarket roller stick, and I'm reusing the factory lifters, dog bones and spider....shouldn't be a problem. |
I wonder if this is what MrPBody was working on back in 2013. He has not posted on any forums for a long time. Hope he well.
Jim is doing well in retirement I talk with him frequently and this is a spin off of his research. I have to give him all the credit for the idea. I’m just finessing and continuing to research and update to get the best parts possible. I have about $140 in the lifters and retainer system. The lifters are much lighter than the retrofit lifters which really helps life.
| The Following 2 Users Say Thank You to 68hotbird For This Useful Post: | ||
What lifters are these?
There were several variations here, hence the question.
These are sealed power lifters don't remember the number off the top of my head but I will get it. These lifters and the others I am trying to make work have run for many miles with 150# of seat pressure and 400# over the nose. If the second lifter I am working with will work there are thousands of them running in high rpm engines with loads of spring pressures. I am still evaluating the effects of total mass on the lifter load. I know our Pontiac valves and rockers are heavier than some of the comparison parts but there are also engines running these parts with even heavier valves, springs, etc.
Thanks for posting this research your doing Just when you think everything that can be done to a 50 year old engine. People keep thinking out side the box. As for the heavy valve train we are seeing guys running the LS like bee hive springs and smaller lighter retainers on all our heads cast and aftermarket.
Might I also suppose that a roller cam with these factory lifters would also not need so much spring pressure because of the lighter lifters?
Sam
Yes these lifters are a little lighter so they are easier to control with spring pressures, so that is another advantage with this factory dog bone setup.
I also prefer to set up the springs with either tool steel or titanium retainers to lighten things up a bit. Every little bit helps when you're doing engines with heavy valves, like Pontiac or BBC stuff. Just curious what factory roller lifter would work in a Pontiac block without block or lifter modifications. |
They are doing the same thing using factory lifters and spiders from the later 3800 GM V6 into the earlier grand national V6
Sent from my SM-T817V using Tapatalk |
I've used Howard's HYD roller lifters...run em for 5+ years really hard with no problems.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning. |
#38
Howard's for Pontiac?
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
#39
Here ya go 350 bucks on facebook marketplace.
Includes cam and timing gear set that won't be used. |
#40
