Old 02-07-2020, 01:55 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by JC455 View Post
I was thinking about roller lifters last night, and had a thought... Harley V-Twins have had hydraulic roller lifters in them forever.
Anyone have a spare H-D lifter to measure?
No need, Google shows they use the too tall Chevy lifter.
Imagine HD saved $$$$ using a ultra common lifter.
The Following 2 Users Say Thank You to 242177P For This Useful Post:
  #62
Old 02-07-2020, 03:29 PM
JC455 JC455 is offline
Bummer
John
IG: @crawdaddycustoms
  #63
Old 02-07-2020, 09:42 PM
68hotbird 68hotbird is offline
Default lifters
The ht2148 sealed power lifter works. With the ford style dog bone and a .335 lobe lift the barrel does not come up far enough to hit the dog bone. This would become an issue if you added another .040-.050 lobe lift or more. Just more info.
  #64
Old 02-08-2020, 10:54 AM
Hmm, all the rollers we run are over .600 at the valve or around .380+ lobe lift so that likely won't work.
  #65
Old 02-08-2020, 11:49 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Wouldn't it depend upon the base circle?
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
  #66
Old 02-10-2020, 07:10 PM
1994-03? 60° V6 lifter on base and full lift. Note this is with a Summit 2801 so the base circle is somewhat smaller.
ID:	531610   Click image for larger version
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
  #67
Old 02-10-2020, 09:30 PM
dmac dmac is offline
Would a higher ratio rocker make up the difference? Of course, that doesn't help the affordability.
  #68
Old 02-11-2020, 12:56 AM
FrankieT/A's Avatar
And what about the Olds 307 lifter mentioned earlier? Same diameter as Pontiac? Oil band in the right place? It seems it was dismissed earlier in the thread...
  #69
Old 02-11-2020, 01:26 AM
Outside Diameter 0.9210
Type Hydraulic
  #70
Old 02-11-2020, 12:43 PM
So, for a street car- (4/7 swap)cam- would this work nicely with the HT-2148 lifters? Still too much?
Camshaft Type: Hydraulic Roller
Basic RPM Range: 1800 to 5200
Valve Lift Intake: .525
Valve Lift Exhaust: .530
Duration Intake: 280
Duration Exhaust: 288
Duration at 050 Intake: 227
Duration at 050 Exhaust: 235
Lobe Separation: 109
Intake Centerline: 103
Firing Order: 1-8-7-3-6-5-4-2
John
The Following User Says Thank You to JC455 For This Useful Post:
  #71
Old 02-11-2020, 12:46 PM
Or this one:
Basic RPM Range: 2500-6500
Valve Lift Intake: .560
Valve Lift Exhaust: .565
Duration Intake: 290
Duration Exhaust: 296
Duration at 050 Intake: 237
Duration at 050 Exhaust: 243
Lobe Separation: 112
Intake Centerline: 108
John
  #72
Old 02-11-2020, 01:17 PM
So, for a street car, this (4/7 swap)cam should work nicely with the HT-2148 lifters?
no, they will not - did you not see several posts noting they will not work?
note this pic - see the oil hole and lifter main body sticking out? Compare that to the pic of the 60° V6 lifter.
Name:	HT2148B in P428.jpg
  #73
Old 02-11-2020, 01:38 PM
OK, there lies my confusion-
68hotbird said
"The ht2148 sealed power lifter works. With the ford style dog bone and a .335 lobe lift the barrel does not come up far enough to hit the dog bone. This would become an issue if you added another .040-.050 lobe lift or more. Just more info."
I was using his number, assuming that was the V6 part number.
John
  #74
Old 02-11-2020, 02:04 PM
No, those are the bog-standard GM V8 lifter from 1987 to mid 2000's. There is a 1997-2000 454/502 that is similar to the V8 lifter but a bit shorter it seems.
I am tempted to order one and test fit. The main reason is Rhoads makes a bleed down version of it and I can run a nastier cam.
  #75
Old 02-11-2020, 02:32 PM
Default lifters
the ht 2148 sealed power lifter works with the hr276 cam I have in my motor. I have not test fit it yet but I have an hr288 I'm going to try next. That last picture with the lifer with the oil hole above the bore looks like the ls7 lifters that I purchased. If they will grind the cam on a smaller base circle the ls7 lifters will work. One thing I will caution is that there are several manufacturers of lifters that use the same part number for small block and LS engines. They will interchange in the chevys with no issues but not the Pontiac. I also have some knock off 2148 lifters that also wont work. The only ones I know for sure right now that will work in my combo is the sealed power branded 2148 lifters. Again this is a cost savings and a reliability project but you must check everything out to verify it works. One thing I noticed that you really have to watch is I have 5 Pontiac blocks in the shop right now and there are several lifter bores that have a chamfer at the top of the bore and some do not. You have to look and measure the chamfered ones to make sure the oil hole is still covered.
The Following 4 Users Say Thank You to 68hotbird For This Useful Post:
  #76
Old 02-11-2020, 09:45 PM
I tested a full base circle roller cam I have and noted that the 60° V6 lifter does not come up far enough out of the bore to properly engage the dog bone at lowest level - only 80 thou sticks out, so I cannot use this solution.
  #77
Old 02-13-2020, 08:52 PM
t money t money is offline
I found this on rockauto today this is think outside the box can the engine tech RFC45416 work with some work. Same .842, a oil hole with no big scallop that can be exposed at full lift. If you drill the Rivets to remove the bbc link bar , it has the flat part of the upper part of the lifter for the dog bone system (replacing the link bar)and if needed look like you can shorten it a little. 24.99$ 2 lifter and link bar. I’m sorry I can’t post the photos. Maybe someone can help.
The Following User Says Thank You to t money For This Useful Post:
  #78
Old 02-13-2020, 09:02 PM
tempest1964's Avatar
Here is a link to the suggestion that t money made:https://www.rockauto.com/en/moreinfo...942752&jsn=258
The Following User Says Thank You to tempest1964 For This Useful Post:
  #79
Old 02-14-2020, 02:23 AM
1997-2000 C3500 w/454 BBC has roller lifters, no tie bar.
https://www.rockauto.com/en/moreinfo...353114&jsn=509
  #80
Old 02-14-2020, 12:55 PM
T Money- That's a great find! If the oil band isn't too large, that may just do the trick!
John
