Old 02-27-2020, 10:31 PM
injectedbird injectedbird is offline
Default MR-1 block water leak ?
Has anyone had water leaking into lifter valley on mr-1 blocks ?
Old 02-28-2020, 08:00 AM
steve25 steve25 is online now
Are the head bolts blind in these blocks?
If not you could just have a one of the top row of head bolts leaking into the valley once pressure builds up as seen many times on SBC motors of yore.
It's time to block stuff off and apply a pressure test to nail it down.
Old 02-28-2020, 09:14 AM
AG's Avatar
AG AG is offline
IAII and MR-1 headbolt holes aren't in the water jackets.
Old 02-28-2020, 09:22 AM
73 TRANSAM 73 TRANSAM is offline
I believe they have a pipe plug fitting in there and they just flat mill it. Its the same as the IA2 set up. Good luck.
Old 02-28-2020, 10:30 AM
gmeyer gmeyer is offline
Default Water leak
YES a friend just had BES build him a super stock engine with a MR1 block and it leaked water in the lifter galley
greg
Old 02-28-2020, 10:50 AM
Got one that leaks at casting marks between the deck and lifter valley. It leaks at 6 spots.
Old 02-28-2020, 10:51 AM
PAUL K's Avatar
PAUL K PAUL K is offline
You guys should contact KRE.... I'm sure they'll make it right.
Go fast, see Elvis!
Old 02-28-2020, 11:01 AM
Are you?
Old 02-28-2020, 11:11 AM
F/S GTO F/S GTO is offline
Mine did it in Vegas last year between races. Was fast at the first race and it kept slowing at the second race. Thought a bearing was going away took the filter apart and saw coolant, must've had 3 quarts of coolant in the crankcase. Long story short took the motor apart when I got home could see the trail in the valley but couldn't really see anything in the deck. When I put it back together I saw a hairline casting flaw so I smeared clear RTV the spot it going to get stop leak when I get it running again. I put stop leak in it when it happened and that did stop the leak.
Old 02-28-2020, 11:32 AM
PAUL K's Avatar
Originally Posted by Scott Roberts View Post
Are you?
Go fast, see Elvis!
Old 02-28-2020, 11:48 AM
gene simmons gene simmons is offline
You would think there would be some qc on castings before being shipped.
Old 02-28-2020, 12:29 PM
They should make it right if there is a problem. I doubt you will get any money back for parts or machine work as it probably should have been pressure tested from the start. For the most part race parts cary no warranty.
Old 02-28-2020, 01:00 PM
Steve C. Steve C. is offline
"You guys should contact KRE.... I'm sure they'll make it right."
Bwahahahahahahahahaha ! !
Old information here:
Old 02-28-2020, 02:03 PM
Richie Hoffman's Avatar
i heard they can leak from head gasket area you have to look at it closely
2008KRE Q16 Winner
Old 02-28-2020, 02:04 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
A friend of mine had the same problem, it took forever for them to answer the phone {as usual}, then they sent him another block . It did the same thing, then they would not answer the phone.
Old 02-28-2020, 02:19 PM
i would contact KRE
2008KRE Q16 Winner
Old 02-28-2020, 08:16 PM
ponjohn's Avatar
ponjohn ponjohn is offline
1 or 2 leaks?
When were these block cast?
Old 02-28-2020, 11:21 PM
6 leaks between the pushrods.
Old 02-28-2020, 11:51 PM
And they come out of the woodwork... hey gto George, , it's time for you to run damage control... kre needs you!
Old 02-29-2020, 05:33 AM
Brian Baker's Avatar
Talking
Are you?
I saw that and my initial thought was "where is the laughing emoji next to the like button?"...
