Electronic controlled transmissions are not new, GM has had them since 1991. Anyway, I talked about the T400, not electronically controlled, and easily able to handle a 500 HP Pontiac with just a few modifications. I do believe the OP was originally concerned about breaking transmissions, and asked for input. I offered input based on my own past experiences. After looking at the pictures I don't think it's a weekend street driver.
From the pictures posted, the OP looks to have a dedicated race car, if he has gone to the trouble of building a race car he might want to win races, not go out and have "fun" shifting gears with a 4 speed............... ![]() Not too many people on this board have driven closed course cars as 99% have drag cars and the race section is almost entirely devoted to drag racing. If that's what floats yer boat, that's fine. I myself like other forms of racing, and have participated in them as well. If the OP was dead set on a stick car, then he can disregard my comments. I didn't get the idea from asking for input, that there was no consideration of any other transmission, but then I have no idea of his criteria, for his car. I have a tendency to not follow the crowd, and work/look outside of the box. Innovative ideas win races, not following what everyone else is doing. A friend of mine that raced circle track for many years put it in perspective. Quote:
![]() Quote:
My 70TA has a TH400 in it and it's seen plenty of autocross and track days and I can assure you that your right, if it was a 4 speed car I would have been slower! Sent from my SM-A530W using Tapatalk
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15. 1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-( 1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-( |
![]() Quote:
I was once told by a pit steward, that my 67 GTO, (in the second pic in my signature), had too many bars in the drivers door, WTF............... ![]() ![]() My response was that it was my A$$ sitting in that seat, and when their butt was in the seat would they want less protection? That ended the discussion pretty quickly. One time at a drivers meeting I broached the subject of oversize wheel studs not being allowed. The track owner said a wheel coming off a car adds a little excitement for the fans. I then said, that a wheel going into the grandstands should be the ultimate in excitement .............. we were allowed oversize studs after that exchange.......... ![]() Stay safe in your pursuits, there are no good wrecks in motorsports. I hate to see anyone taken out of their cars, and put into an ambulance at any racing venue. Go fast, but be safe above all. Kick A$$ with a PONTIAC. |
![]() Quote:
Paul offers an array of options including gear ratio's. Give him a call or checkout his youtube video's.
Home of WFO Hyperformance Shaker induction. |
So you banged the gears hard on the new tranny?
![]() Quote:
The 3.42 gearset has the lowest torque capacity rating of the available Super T-10 gear sets. The 3.42 main drive gear(gear on end of input shaft) is much smaller in diameter than the gear it is driving on the front of the cluster gear. The strongest arrangement is when the input gear and the gear it drives on the cluster gear are closer to the same diameter. So that means that the closest ratio unit will be the strongest. The 2.43 close ratio gearset is the strongest of the Super T-10 gearsets and is identified by 2 identifying grooves on the input shaft spline. As far as not using 1st gear and avoiding drag race style launches, that will definitely help it live longer. But dont forget; the power flow for the speed gears 1st, 2cnd and 3rd flows through that same weaker maindrive gear and front cluster gear combo. To illustrate, the 2.43 gear set has a 21 tooth maindrive gear driving a 28 tooth gear on the front of the cluster gear, while the 3.42 set has a pitifully small diameter 17 tooth input shaft driving a much larger dia 31 tooth gear on the front of the cluster gear. Power flow for all gears except for 4th flow through the maindrive/cluster gear pair. Curious, where did you get the 904 nodular iron case and is this a 1st design Super T-10 or a 2cnd Design Super T-10....or is it a Richmond (basically a 2cnd design)? From a HotRod online article: " the Super T10 that Pontiac specified for its high-torque 400 and 455s was a close-ratio unit with a First-gear ratio of 2.43:1, which happens to boast of the greatest torque capacity rating of any Super T10. ........... As years progressed, new lower-ratio gear sets were developed, and by 1980, a First-gear ratio of 3.42:1 was used with 301ci Pontiac and 305ci Chevy engines. The number of gear teeth required to achieve that ratio made the gears vulnerable. The above speaks for itself .. wouldn't you say? Here are the available gear-sets as listed by Richmond gear. Last edited by 10secbird; 03-15-2020 at 06:14 PM. |
So I have been looking around, and there is a tex racing ST10 not too far from me. Would be able to possibly trade from some parts I have...anyone have experience with these? It's not the T101 tranny but still a Super T10...
https://www.kijiji.ca/v-transmission...-10/1491914950
I have a t101 going in a project now. Sitting next to a stock t 10 it looks like a heavyweight vs a lightweight. The tailhousing has 5 bolts, the case is way thicker.
It will hold much more horsepower. The shifter set up on that one is great too. |
![]() Quote:
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 03-18-2020 at 08:56 AM. |
Hey Skip! Yes but I ditched the drag radials after grenading the last tranny. I'm running Nitto 555's street tires now, so the bite is not near as "tacky".
Picked up the transmission today and decided against the shifter for now, ill first see how things fit and go from there (moving the motor back and down in the car)
Transmission looks perfect, really happy I grab this and won't have to worry about the other tranny Sent from my SM-A530W using Tapatalk
