| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
#61
I didn't have them long enough to know. "Gotta know when to sell/hold em ".
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
#62
Worst car ever; 1957 Olds super 88: replaced 5 starters, 5 generators, 3 voltage reg, rear wheel bearing, radiator, carb, & an engine fire!!! got rid of it 3 weeks after I got married on a 1962 Le Mans 4 cly 4 barrel. Had that car for 10 years with 99,000 miles when it was finally too bad to keep. B est car, 1987 Ford Ranger STX V-6 5 speed had for 28 years.
#63
Same issue with Toyota four cylinders after 2000. Don't know if it was ever fixed or that Toyota is ignoring the problem
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
#64
Funny--My first car was a '57 Old's Super 88. As you may know, all the '57 Old's had camshaft failures due to too much spring pressure. Needing to replace that cam and lifters is what got me started on being a car guy. I remember we pulled the pan to clean it out, but the bearings looked OK, so we buttoned it up and ran it. Put J2 on it and sold it so I could buy my '64 GTO. Loved the Old's--but not as much as the GTO!!
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
#65
The worst car was a 1985 Camaro Z28. It spend more time in the shop than me driving it. The best car is the one drive now. 2012 Toyota Sequoia.
#66
I agree. I have never had a POS, although I have worked on a lot of them for other people. I still have my two good cars. My '66 Pontiac Tempest wagon, and my 1974 Olds Cutlass Supreme. The 326 2 bbl in the Pontiac and ST 300 transmission went for 293,000 miles, pretty much trouble free, with nothing but a timing chain, a couple of water pumps, and wear items on the car itself, such as brakes and axle seals. That was what the odometer was at in 1987, when I purchased the Olds from an aunt, with 135,000 on it. My intention was to retire the Pontiac from daily driver status, building it into a fun weekend car, and use the well kept Olds for that. Worked out very well. The Olds accumulated even more miles than I had on the Pontiac. It ran like the energizer bunny, up to 500000 miles. At that point, in 2013, the Olds 350 was getting weak, but no knocking or smoking, so at that point, I rebuilt it. It had nothing but weak tension on the rings, and weak valve springs. Very clean inside. The TH350 has been rebuilt 3 times, and the 10 bolt axle, once, with new bearings and seals, using the original 3.08 ring and pinion. The Olds is a very comfortable cruiser, with power windows, buckets, console, ac, tilt column and 4 spoke sport steering wheel. Has a substantial feel, and I have been all over the east coast a few times with it. have had it repainted 3 times. The car still looks good, and rides like a dream. The Pontiac handles great with my suspension upgrades, and pulls strong with the 455 /TH400 transplant. In 2014, my dear Dad passed away, and I inherited my Moms 1993 Buick Regal with a 3800 from him. That car is a sleeper of a gem itself, although I am not a fan of what I consider "newer" cars, it makes a very reliable car to drive back and forth to work. It "only" has about 165000 on it. Doesn't burn oil, and drives very nice.
#67
LOL! I owned an '05 Corolla that went to 247,000mi. before I sold it and a '03 Prius with 367,000mi. with the original Hybrid battery bank and neither one had a problem outside of a fuel pump and a vapor canister on the Corolla. The only reason why I didn't use either one of them as my best is because my '77 GP SJ was the best "all around" car.
#69
#70
Worst car ever....DKW! 2 cycle, beast that couldn't handle, stop or go! Best ever.......62 Catalina 425A, 4 speed.
My money talks to me-it usually says goodbye! |
#71
I have a 2003 suburban 4w/d 6.0L motor, it continually alarm codes the throttle body sensors not matching. Every dealership I have gone to says I need a new throttle body, I personally replaced them and the sensor comes with it. Within less than 1k miles it alarms again, last dealer wanted $11k to replace and reprogram, last repair shop $650.00. I now have 3 throttle bodies in my garage, (all GM products), no one seems to know the real problem. I have written nice and bad letters to GM and also have heard nothing. My wife has a '99 Tahoe that still runs with minimum maintenance beyond the typical age related items but I will not look to GM for anything new, I only respect my "70 GTO!
#72
My Best and most reliable car I ever owned was also one of my ugliest, a 1977 Buick Century Wagon that I traded a Gallon of Captain Morgans Rum for in the Mid 1980's. It had 66,000 miles on it at the time, didn't run (bad Coil on the HEI) and had been used as a winter car by the previous owner from new. It was Turd Brown in Color, the front fenders & Rear 1/4's were rusted beyond saving when I got it. But the floorboards had been rust proofed by the leaky Buick 350! I put over 250,000 miles on the car, hauling Greyhounds up from Florida & Alabama, and as a work car & general beater. Other than the usual Brakes, Tires & Tune ups it only needed a rear seal on the TH400, 1 set of U-Joints, and the rear axle went at around 290,000 miles. Also rebuilt the front suspension at around 200,000 miles. The gas tank finally developed a leak just short of 330,000 miles and I just could not justify replacing it. Heck the A/C Still worked! It only needed a couple of lbs of R12 a year added to it.
As for the worst car we owned, had to be the 1988 AWD Mercury Topaz that came with my wife! No power, no MPG, nothing but driveshaft issues and suspension issues. Even changing the Serpentine belt (it also had 3 V Belts) was a pain as it actually went around the passenger side Motor Mount! I was glad she finally rear ended some one at a stop light (at about 5 mph) and pushed the transmission cooling lines back so hard it actually cracked the transaxle case between the 2 lines causing it to look like it was bleeding to death from the seeping fluid!, White car red fluid.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
#73
Going through the previous postings I took notice of the experiences members have had with GM and Ford trucks and full size SUVs. Most share the same drive trains and similar chassis, and this is the rough count I came up with.
GM positive opinions at 2 GM negative opinions at 9 Ford positive opinions at 10 Ford negative opinions at 2
#74
I just feel new vehicles are simply to expensive. Quote:
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘67 Corvette 427/435 ‘23 Lexus LS500 awd ‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars) ‘95 Ford F250 4wd 7.3 p-stroke & countless Jeeps & off road vehicles & motorcycles |
#75
Take a look at the Camry forums.
73 pages worth. https://www.toyotanation.com/threads...thread.325124/
#76
Worst.....1981...4 cylinder Chevy Citation!!!!!!
#77
Still driving my 1999 Honda Accord I bought brand new and a 1984 Toyota SR-5 pickup that was passed down to me in the mid 1990's. Not considered "fun" vehicles by most standards but fuel efficient and reliable mechanical marvels are were they excel.
I also call B.S. on Toyota Camry head bolts problems. My folks own a 2001 Camry 4 cyl 5FSE and it's about to crest 285,000 miles with an untouched engine/trans besides regular scheduled maintenance. |
#78
Jimmy M 68 GTO |
#79
Best, 2004 Dodge Ram 1500 4x4 bought new wife drove for first 150,000 now my work truck with 344,000 and still going. Getting rusty and a little soft suspension wise
Worst, 1985 Ford F-250 460 4 speed, leaked oil bad rebuilt engine (1990) ran great but rusted bad in the next 3-4 years. 2 leafs broke and feel out going down the road. Worst, 1987 Ford Aerostar ( early 1990’s) don’t even ask if it could go wrong it did and rusted to the ground. Worst, 2005 Ford Taurus (2010ish) got it with 95,000 sold it at 140,000 after putting a transmission and a heater core in it. |
