Making the move to E85. I just purchased a radiator and bought the wrong one. I can make it work without too much trouble but it's a lot smaller than the factpry size. I believe factory is a 27" core width and this one is 20". How much cooler will it run on E85? Should I send it back and get the bigger radiator, or will it cool just fine with E85? Thanks.
http://www.youtube.com/watch?v=t9eWgLd0q-U |
We have used E85 for a very long time, I have never noticed it to run any cooler than gas.
Saved a lot of fuel money though. |
| The Following User Says Thank You to Dragracertoo For This Useful Post: | ||
agree. I think people, like myself, expected it to run cooler alot like methanol. It does not, in my experience. I have a car that never ran hot on race fuel, not run hot on e85, in part to it haveing a larger street car tyl radiator system. I bought a car set up for alky with small scirroco radiator, converted it to E85 and had trouble keeping car cool. I added a better radiator and now it is manageable going rounds. Over kill the cooling and everything on your bracket car, and i highly support 16v batteries and quality fans, and mezeire pumps.
It is great cheap fuel
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
I bought the thinnest radiator on eBay that still bolts into my core support. I used to run a four core radiator when I ran race gas. With the thinnest lightest duty radiator I still have to run my engine in the staging lanes to put heat into my engine. Any less than 160 as I enter the burnout box, and I’m flirting with disaster, because if it’s not 170+ on the line it will stumble. I’m usually 180 when I launch. When I’m in the late rounds I’ll tell my opponent to NOT start his engine until I give him a thumbs up. Just because I start my engine doesn’t mean it’s up to 170, and it takes a minute or two to get that heat I need, unlike the gas burners, they like there engines as cool as possible.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
