Old 05-07-2020, 03:47 PM
[email protected] raphsutton921@gmail.com is offline
Default Drums to disc
Hey Gas I’ve been trying to convert my drums to disc on my 70 Catalina that I have contact the scabird no luck I’ve contacted rice stuff no luck can anyone help
Old 05-07-2020, 05:49 PM
Schurkey Schurkey is offline
Take more time with spelling and punctuation? Maybe your e-mail isn't being received because you mis-spelled the e-mail address.
Old 05-07-2020, 06:25 PM
U know that really did not help me but ok thanks
Old 05-07-2020, 06:37 PM
This may be of more help:
http://forums.maxperformanceinc.com/...28#post6122528
Old 05-07-2020, 06:43 PM
I posted that I have contacted them and right stuff and neither of them have anything
Old 05-07-2020, 06:47 PM
Bill Hanlon's Avatar
Disc brakes were an option on 70 Pontiac Catalinas. Why go aftermarket?
Old 05-07-2020, 06:49 PM
So what do I do to change it from drums to disc
Old 05-07-2020, 06:58 PM
John Milner's Avatar
I would use original parts too. I would get the spindles, caliper brackets, rotors, proportioning valve, and lines to the proportioning valve all used. Then I would buy calipers, pads, rubber lines and master cylinder new. Should be basically a bolt on job.
Old 05-07-2020, 07:22 PM
Can u guide me in the right direction as in where to call cause autozone orileys Napa says no on spindle and rotors
Old 05-07-2020, 07:50 PM
Thanks I appreciate it I have found everything except for the spindles
Old 05-07-2020, 07:52 PM
Well you’re going to need to source those from a parts car. Just get the pads, calipers, rubber brake hoses and master cylinder from a parts house like Napa. You’ll need the spindles, rotors, caliper brackets and proportioning valve off of a parts car. You might post a want add in the forum for those used parts.
Old 05-07-2020, 09:50 PM
Firebob's Avatar
Firebob Firebob is offline
You should be able to buy the spindles from Summit.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-08-2020, 12:03 AM
They do not list those. As stated, very low demand - best to contact one of the big yards, like French Lake in MN and get a OEM spindle.
Old 05-08-2020, 06:25 PM
SRR's Avatar
SRR SRR is offline
Where did you find the rotors? They haven't been available after market for a long time. You might want to contact Frank:
https://www.facebook.com/search/top/...epa=SEARCH_BOX
― Calvin Coolidge
Old 05-09-2020, 12:04 AM
How do I contact frank
Old 05-09-2020, 12:05 AM
No spindles on summit but they have everything else
Old 05-09-2020, 06:56 AM
Have you checked with [email protected] for the spindles?
Old 05-09-2020, 04:13 PM
SRR's Avatar
SRR SRR is offline
Default This:
Here:
― Calvin Coolidge
Old 05-16-2020, 07:55 AM
400 Lemans
I have an alert that’s u posted something and I can see it in my email but not on here is there anyway u can get me that contact for the brackets u showed me
Old 05-16-2020, 09:05 AM
400 Lemans's Avatar
https://www.facebook.com/marketplace...4119882019282/ Not mine but they may work for you. There rusted but the spindles would clean up.
