#121
I talked to Wally at CC to get clarification on the cleaning instructions before I installed them last summer and he said the outside can be cleaned with solvents but soaking them in solvents will dissolve the grease in the wheels and specifically said not to do that. Just passing along what Comp told me.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
#122
Instructions from revised form dated 7-19-2020
Including Comp Cams part number 857-16 Pontiac hydraulic roller lifter Instructions: 1. Lifter cleaning: Remove your new COMP Cams® lifters from the packaging. The lifters need to be cleaned with mineral spirits or parts washing solvent first to remove any debris from shipping or handling. Also check to ensure that the wheel rolls smoothly. NOTE: Rollers may feel as though the wheels drag more than expected due to the grease packing for assembly and break-in. This is normal. WARNING: The wheel needle bearings are pre-greased with special OE grease. While cleaning, be careful to NOT blow out this grease for this is very vital to initial break-in. Also do NOT clean with aerosol cleaners! And do NOT allow the wheel to be spun by compressed air. 2. Lifter preparation: It is not necessary to “pre-pump” hydraulic lifters full of engine oil prior to installation and valve adjustment. It is actually undesirable to do so as the “pumped up” lifters will cause the valves to open during the adjustment process, rather than positioning the lifter plunger in its operating position as it is supposed to do. Next, soak the lifters with COMP Cams® Break-In Oil (Part #1590) or equivalent for at least two hours. Doing so ensures that the lifters are adequately lubricated on their outer surfaces prior to installation. It may also result in a quieter engine start-up as the oil in the bath may displace some air from the lifter’s plunger reservoir. When you install the lifters, make sure they fit well. Any excess clearance or tight lifters can cause damage to the camshaft, leading to engine failure. Verification of lifter to lifter bore clearance is recommended. Note: Contact your engine builder or block manufacturer for your specific clearances. https://mail.google.com/mail/u/0?ui=...tt&disp=inline .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 06-01-2020 at 03:04 PM. |
#123
I’m starting to look at the 286-ah8 sitting on the shelf 👀
#124
I haven’t used ANY Comp Cam product since the mid 90s when they had problems with soft cam cores (BBC). They knew it, but always claimed improper break in. There was 8-10 of us that all had issues. Every one of us went to a different brand of cam and lifters and never had another wiped lobe.
#125
ever check the cam shaft end play? too much lateral movement will destroy a roller lifter in short order
Scott Sims Sims Performance Machining LLC P.O. Box 184 Elizabethtown, Indiana 47232 phone... 812-350-8637 [email protected] |
#126
This thread is really pushing me to Ebay my new CC Hyd Roller lifters and purchase the Johnson lifters. My CC lifters are still new in the box.
#127
This and old worn/honed over sized lifter bores
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
#128
Went through that months ago. Paul was already waiting 6 months for them calling every so often, and I waited another 2-3 months with still no date, so I gave up. I did 2 engines and 2 roller cams in that time frame and still no Johnsons available. It's been a few months since then so maybe they are out there and available now. |
#129
Has anyone tried running these?
Hy-Lift Johnson Pontiac SE Retro-Fit Hydraulic Roller Lifter with Pressure Pin Oiling Set/16 HLJ-2347SE
Tim Corcoran |
#130
Is it just me, or does that wheel now look like it has a pronounced taper? I'm thinking that wear looks fairly even, as in it didn't happen overnight? Could the lifter could have been slightly cocked slightly sideways, from like a loose (or even misaligned) link bar??
#131
Wow, that's been quite a while now. Next time I talk to Paul I'll have to remember to ask him what he's using.
#133
I am the one that got Jay S into the middle of this controversy by PMing him that when I bought my HR lifters with cam from Bullet, Tim Goolsby told me they were made by Morel. Mine look like the first picture in Jay's last post where he has 2 pictures. Mine have that little ridge in oil groove below oil hole. Also on the instruction sheet (which does not have Bullet's name on it) the very first line says "Installing and Adjusting Morel Lifters" and at the bottom of the page it says "Copyright 2017 John Callies, Inc. All Rights Reserved". (I bought cam and lifters from Bullet January 2018.) So in the words of Forest Gump "And that's all I know about that". Up to you guys to figure it out.
#134
Sorry I put above post on wrong thread. Moderator would you please move it to "Hi-Lift Johnson Hydraulic Roller Thread" please, thank you.
#135
GM, Chrysler and Ford, all have issues with roller lifters/ camshafts. I dont know who their suppliers are, but I dont think any of them make a lifter/roller that lasts forever. I don't know why they fail, but its always a roller, with a flat spot. So is it material?
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#136
Just thought you all should know,Comp Cams is giving me a new set of lifters...
#137
I can't say we've had the same experience with other lifter companies. |
#138
