Well assuming the 400 will be .030" over, and then also assuming your 1974 350 cid # 46 castings where no more then 96 CCs in stock form, you then will need a maximum of 116 CCs of volume total at TDC to have a 9 to 1,compression.
Some normal CC numbers to add to your chamber volume are Head gasket =9.4CCs. 4 valve notch Pistons = 6.7 CCs. .023" deck clearance = 5.097 CCs. Top Ring land volume= 1.5CCs. And lastly the valve job done to the head likely added 1 to 1.5 CCs to the chamber volume. Milling the head .030" will knock off 5 CCs.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 07-01-2020 at 07:19 AM. |
I used stock 7K3 heads rebuilt.
