Old 06-07-2020, 01:07 PM
ErikW's Avatar
ErikW ErikW is offline
Default More Progress
Nick has been busy on the floor and now is contemplating smoothing out the firewall. The factory firewall on this car is hideous. There is a big fold right in the center. I think he is going to cut it out and weld in a new flat piece before joining the tunnel back to it.
ID:	541938   Click image for larger version
ID:	541939   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #102
Old 06-07-2020, 01:22 PM
ErikW's Avatar
Default Heads!!
Got the first head from Dave Bischop at SD Performance! Awesome work. Second head should arrive later this week.
Name:	Head Specs.jpg
ID:	541947   Click image for larger version
ID:	541948   Click image for larger version
ID:	541949   Click image for larger version
ID:	541950   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #103
Old 06-20-2020, 01:54 PM
ErikW's Avatar
Nick decided to cut out all of the ugly sheet metal on the firewall and replace it with flat sheet metal. I'll smooth all of it out before we paint it. Also installed the rear ant-roll bar and sent the rear housing off to be powder coated. We sent the fender air extractors out also to be ceramic coated black. It's really starting to get humid around here as you can see from all of the surface rust on everything.
Pretty soon she'll go back on the rotisserie and we'll get to work sanding and epoxy primering the entire car inside and out. Then body and paint. Just have a few more tabs to weld on and some of the front structure to finish.
ID:	542787   Click image for larger version
ID:	542788   Click image for larger version
ID:	542789   Click image for larger version
ID:	542790   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #104
Old 07-08-2020, 10:19 PM
ErikW's Avatar
Default Rear End
Got the rear back from powder coating. Looks sweet. Nick made me an awesome 9" holding fixture.
ID:	544572   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #105
Old 09-14-2020, 01:28 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default Updates?
Any updates on this awesome project? It has been fun following it thus far.
Thanks - Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
  #106
Old 09-24-2020, 06:08 PM
ErikW's Avatar
Well, since Drag Week got cancelled we took some time off to address some much needed home repairs, install Tiger heads on Nick's 86 TA drag car and just take a break. We will fire things back up in November and finish this bad boy. Stay tuned.
Erik W
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #107
Old 09-24-2020, 06:14 PM
ErikW's Avatar
Default Nick's TA
Quick video of first fire on Nick's Tiger Headed 535
https://youtu.be/l1XNjz3_c34
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #108
Old 10-30-2020, 11:53 AM
AIR RAM AIR RAM is offline
Are those bolt hole inserts on those heads?
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
  #109
Old 10-30-2020, 06:40 PM
Yes, I have the same inserts in my SD Performance heads that arrived about 4 months ago.
Dave does really nice work.
  #110
Old 11-15-2020, 08:19 AM
ErikW's Avatar
Yes they are Nick. And yes he does Tom. I'll be posting more soon as I'm finishing up my honey do list this week.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #111
Old 11-15-2020, 12:28 PM
GTOGEORGE's Avatar
You may also want to consider using a ARP2000 stud for your heads, I have them on my race car with hp heads and are working great!
GTO George
  #112
Old 11-23-2020, 08:54 AM
ErikW's Avatar
Working with Luhn Performance on ARP Head Studs. Super secret stuff.....
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #113
Old 11-23-2020, 01:57 PM
GTOGEORGE's Avatar
i already have the Super Secret stuff, only I'm telling everyone!
Maybe Luhn outa talk with me!
GGTO George
  #114
Old 11-23-2020, 06:14 PM
Yeah, I was talking to him about those... I will also most likely end up going that route as well... I did end up going with his Super/Secret Cometic Head Gaskets...
The build looks amazing man.
SPEED SAFE, NICK
  #115
Old 11-24-2020, 12:45 PM
ErikW's Avatar
SPEED SAFE, NICK
Yea, we have both. Can't wait to test them out
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #116
Old 11-26-2020, 10:52 AM
What CR and fuel are you planning on running with on this build?
SPEED SAFE, NICK
  #117
Old 11-26-2020, 11:03 AM
ErikW's Avatar
Should come in around 9:1 and we'll be using pump gas for the street and E85 for the track. Two fuel systems and 2 sets of injectors. Eventually we will run methanol exclusively. The dual fuel system is for Drag Week where we can only run E85 or race gas for the class we are targeting. For regular drag racing like Norwalk and the like, we will run Methanol. Lots to sort out. Finally finished my last honey do project yesterday and we'll be back at it shortly. I'll be posting building of the 4L80E, the engine completion, body and paint work and wiring this monster.
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
  #118
Old 02-18-2021, 07:40 PM
ErikW's Avatar
Default Finally back on the Bandit
After Covid reeking havoc on our household, my wife, myself and my son all came down with it. We are finally back in the garage. Fitting panels and fiberglass rear bumper. Then we blew the car apart and put it back on the rotisserie for final floor pan welding and then we're having a wire wheel/sand paper party to strip this thing back down to bare and shoot it with some epoxy primer.
It's been a tough couple of months for us and we're just now feeling up to it. My plan is to have color on it by Late April or early May. Hopefully have it on the track sometime in June. We'll see.
ID:	561081   Click image for larger version
ID:	561082   Click image for larger version
ID:	561083   Click image for larger version
ID:	561084   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #119
Old 02-18-2021, 07:55 PM
ErikW's Avatar
Oh yeah, we did manage to get the chassis cert in our down time.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #120
Old 02-21-2021, 08:22 AM
Got any pictures of the oil drain routing for the turbos?
Normal downhill drain or are you using a return pump?
