Old 08-14-2020, 02:46 PM
JLMounce JLMounce is offline
There is a gentleman that had posted in one of the pontiac facebook groups about doing this.
He used the Sealed Power 2148 lifter which apparently matches the lifter bore oil feed correctly. I believe that is an LS7 lifter. He used the ford spider part 31-1000.
Per his post the modifications necessary were to cut the slightly reshape the spider to fit the dimension of the lift galley so the forks are properly located. Additionally the block side portion of the forks must be ground slightly to allow them to sit flush against the top of the lifter bore.
-Jason
1969 Pontiac Firebird
  #102
Old 08-14-2020, 04:21 PM
webfoot's Avatar
webfoot webfoot is offline
Do you happen to know what the FB group is called?
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #103
Old 08-14-2020, 05:51 PM
It was the Pure Pontiac Powered Outlaws group. The information is in a post related to Johnson Hydraulic Rollers
-Jason
  #104
Old 08-14-2020, 06:41 PM
He used the Sealed Power 2148 lifter which apparently matches the lifter bore .
He’s a member here also, Archerytony I believe. He hasn’t been on here in several months though.
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
  #105
Old 10-24-2020, 09:40 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Tony just posted the same information again - same group. He has several thousand miles on his build with the LS lifters. No issues. Jim Lehert built the engine, good to know it came from a Pontiac guy.
  #106
Old 12-31-2020, 10:37 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Default LS lifters in a Pontiac? Hmmmmm
Sorry if it's a repost but I just saw this on YouTube this morning. Pretty interesting.
https://www.youtube.com/watch?v=fAKTh3uWBrE
  #107
Old 12-31-2020, 11:19 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Saw that too, anyone on here have any first person experience with using LS7 lifters in a Pontiac?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #108
Old 12-31-2020, 12:19 PM
70 bird's Avatar
70 bird 70 bird is offline
Very interesting!
  #109
Old 12-31-2020, 01:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Not using the LS7 lifter in a Pontiac but plenty with them in LS engines. They were the "go to" lifter for the LS engine until two years ago when they started having ticking issues. These were lifters purchased from GM Hopefully it's been corrected.
Go fast, see Elvis!
  #110
Old 12-31-2020, 02:35 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
subscribed
Old 12-31-2020, 04:10 PM
Thanks, very helpful for me.
The 0.442" lobe on me cam creeps me out.. I probably need to trade roller cams, for a smaller Street Roller.
  #112
Old 12-31-2020, 06:37 PM
Formula8's Avatar
Formula8 Formula8 is offline
I had a 28,000 mile C6 Z06 and it ate a LS7 lifter in the first week I owned it. After doing a lot of LS homework, I concluded no GM LS lifters are long term reliable in a performance application. I am sure some use stock truck lifters with in their 1000hp LS builds but you see many with issues as well. I ended up ordering a set of Johnson's from Paul K (Fair price and hand delivery!). The car was quiet when I sold it.
That said, our retrofit lifters have issues as well. Looking at the video @ 2:00 mins, it appears the lower part of the band is lower than the Pontiac lifter. I wonder if that is going to be a problem?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
  #113
Old 12-31-2020, 08:12 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Default LS 7 hydraulic roller lifters
I have seen on another Pontiac site where guys are replacing their comp hydraulic roller lifters with ones from the LS7. There's also a YouTube video crediting Jim Lehart with this modification . Apparently the lifters are more cost effective, lighter than other Pontiac retrofit brands, and made in the USA
Anyone here trying them, and where there any issues?
  #114
Old 12-31-2020, 08:17 PM
Mr_GTO's Avatar
I think we're going to have 15 new threads about this before tomorrow. Check 3 threads down.
  #115
Old 12-31-2020, 08:25 PM
68WarDog's Avatar
Maybe the moderator can delete my thread. Thanks
  #116
Old 12-31-2020, 09:32 PM
i82much's Avatar
i82much i82much is offline
How is Jim doing? We had our political differences but at the end of the day I believe Jim Lehart is a good man. I kind of miss having him around!
  #117
Old 01-02-2021, 10:38 AM
boardog boardog is offline
this is the you tube video
https://youtu.be/fAKTh3uWBrE
  #118
Old 01-02-2021, 11:42 AM
rohrt rohrt is offline
The video stated the LS7 lifters were about half the weight. Is that true?
  #119
Old 01-02-2021, 12:00 PM
tom s tom s is offline
im sure they are lighter as they are shorter because of no link bars.Does not sound like its a retro fit deal as the block needs to be ground a little above the lifter bores.Might be a good option for new builds.Again,chevy lifters so there could be oiling hole issues?Tom
  #120
Old 01-02-2021, 12:27 PM
grivera's Avatar
grivera grivera is offline
Credit given to Jim Lehart (CVMS) at start of video. I spoke with him years ago and he mentioned he was working on this but never heard it again till now.
Will Rivera
