Old 08-10-2020, 04:40 PM
Finally got it on the road, whew. Still have a few things to do, front end alignment, exhaust welded up, AC charged, and some minor tuning stuff.
Have detail work to do too, as well as a couple scratch repairs that occurred during assembly. Uhg.
Running a little warm, in traffic, it got to almost 205, hotter than I like it to be, prefer the 190 range. May just be some timing needs to be pulled out, I will play with it.
Weird issue with the DBW too, sometimes from a stop, I hit the peddle, and nothing happens. If I let completely off, and try again, it works. Or if I keep depressing until it gets to like a 1/4 throttle, that works too, but it's spinning at that point.
ID:	546838   Click image for larger version
  #222
Old 08-22-2020, 11:10 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Awesome build. I skimmed thru it from the beginning and I may have missed it but what is “DBW”? I’m guessing drive by wire?
I’m considering a similar build, and just found this one. Mine is a 70 GTO my dad and I rebuilt, that he has lost interest in. It’s a “finished” car, but he’s decided to pass it on to me as he doesn’t get to enjoy it much anymore. It’s a fairly original setup (not numbers matching and nowhere near concours, just basic 70 GTO stuff). I’m considering stuffing my IA2 motor in with a different cam (currently setup as a race motor), along with fuel injection, and air conditioning (vintage air). May drop the stance down an inch or two and stuff some nice 17” or 18” wheels under it.
Anyway, you’ve already figured a lot of this stuff out so I may be filling up your PM’s in the future. Need to sell the race car first.
Nice work
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
  #223
Old 08-23-2020, 08:42 AM
Yes, Drive by Wire, used a CTS-V throttle body and pedal. A little bit of a learning curve, but luckily Andrew70 is helping with the tune.
As an update, I got the exhaust welded, and have put about 200 miles on it so far. Still doing some fine tuning, but it's very close.
During the front end alignment, it was determined I can't get the settings I was hoping, so going to switch to offset upper A-arm shafts. That will allow me to add even more caster, which is roughly 4.75 now. If I try to go more, I can't keep the camber in check. Offset shafts will allow me to go to like 5.5-6 degrees of caster, looking forward to that.
I'm using a 2010 vette fan controller, and found out it only supports about 32amp load, so I'm in the process of adding another, and will run each fan on it's own controller.
I have the Billet Specialties billet alt, and, on a drive last week, it quit charging. Did all the typical tests, and it certainly has stopped charging. Luckily, the alt is built by PowerMaster for Billet Specialties, and a quick call has me sending it to them. They say they can turn it around in a day, so by next weekend I should be back on the road.
  #224
Old 08-23-2020, 11:33 AM
vertigto's Avatar
vertigto vertigto is offline
Which A-arms are/were you using?
  #225
Old 08-23-2020, 05:06 PM
I have the global West CTA-42A, and need the same ones with the offset shafts. I recall before I was only able to get about 4.5 or so caster, and forgot during the rebuild, or I would have replaced them.
I can swap the shafts on them, but its not a simple task with the del-a-lum bushings.
Here's the vid on YT from Global West on how to install the offset cross shaft in the GW upper arms:
https://www.youtube.com/watch?v=rEkj340Zt7g
I will call tomorrow and see if they offer the arms with the offset shafts already installed, if so, will buy them, and sell this pair which has new ball joints and del-a-lum sleeves.
  #226
Old 08-23-2020, 08:29 PM
AG's Avatar
AG AG is offline
4.5° of caster is good, you will have a strong centering response with that.
  #227
Old 08-23-2020, 09:02 PM
It's good, I drove it like that for years, but the steering wheel wouldn't return coming out of a turn. With the 670 box in there now, it's even a little worse. And the 670 box with a type 2 pump takes more muscle too. I can live with it though.
Pretty sure I can get around 5.5, maybe even 6 with the offset shafts. Not sure I will like that, but I will see.
I did get the second fan controller mounted, it's on the core support and the batt and batt tray hide it all.
Need to pull the rad to split the wires for the fan feeds, that will take me a couple hours, prob do that tomorrow after work.
I should have the alt back Thurs or Fri, and am upgrading/consolidating a few grounds. Going to run a dedicated 2g from batt to frame, up from a 4g, and going to go 4g from frame to block. (up from a 6g). Going to run a 6g from the block to the back of the case of the alt, too.
Pic of the controller add...
  #228
Old 08-23-2020, 09:39 PM
If anyone is curious, here is a good wire gauge/amp/feet length volt drop calculator:
https://www.wirebarn.com/Wire-Calculator-_ep_41.html
  #229
Old 09-01-2020, 08:49 PM
Oldsboy20 Oldsboy20 is offline
I just found your build thread, I had a question. Do you use Dupli-Color Ceramic Ford Semi-Gloss Black Engine Paint? And do you use a dupli color primer before applying the black paint? Thanks
  #230
Old 09-01-2020, 09:24 PM
Yes. I use the ford semi on all chassis, pulleys, and those type parts, the 1615 aluminum for intakes, ALTs, and other natural aluminum stuff, and the cast iron one for items like tie rods, centerlink, steering boxes, diff center sections, and so on.
On the castle nuts on suspension and steering, as well as other natural hardware, use the semi-gloss clear after torque so they don't rust. I also hit ARP head studs/nuts/bolts after torque, they too can flash rust. Wiper motor bolts, anodized oil pans, etc.
No primer, I've found that the engine paint doesn't 'bite' as well and can flake on primer. I just make sure it's clean, wipe with acetone, and the typical 3 coats as directed of the engine paint. Lasts forever, and easily can touch it up. I blends well too, you don't have to shoot a whole part or area, just the areas you need.
My one old timer body guys says : 'Yeah, that stuff will stick to anything'.
I did the aerosol truck bedliner too, underside, wheel wells, inside of bumper, it lasts a ling time and doesn't get eaten up by rock shots.
EDIT: After the engine paint cures well, you can polish and wax it.
ID:	548432   Click image for larger version
ID:	548433   Click image for larger version
  #231
Old 09-08-2020, 10:59 AM
Got the alt back from PowerMaster, can't praise them enough, the service was incredible. Thank you John is 'returns/tech'.
Put another 200 or so miles on it, the tune is almost complete, just have some shifting programming left, need to soften the 1-2 shift at low throttle.
Ordered the GW control arms with the offset shafts, shafts are getting anodized, they should ship by end of week.
With the GTO endura bumper, the added weight pushed the front springs over the top, and it's sitting too low, and springs are too soft. Ordered some springs from GW when I ordered the upper control arms, but the springs are backlogged to DEC/JAN. Dang. So I ordered some 1/2" pad spacers, which will not only get it off the ground, but also slightly increase the spring rate. I will use those temp until I get the new springs.
Luckily, the springs that are coming out are the exact ones I need for the 442 when I go to the big block, works out for me.
Went back & forth on the trunk tension rods for cars with the wing, have had people debate if it uses a larger diameter rod or not. I couldn't find any larger diameter rods, so I got a aircraft quick release locking pin, and a biker wallet chain, drilled a hole thru the support and trunk arm, and that worked out to my liking. (couple pics)
Still have some minor stuff to do, detailing too, but an enjoying driving it now, so kinda not in too much of a hurry to do stuff!
ID:	549032   Click image for larger version
  #232
Old 09-13-2020, 10:20 PM
So had a Moser 12 bolt built for me a few years ago, TruTrac, shortened housing 1/2" on each side, tapered bearings, 373 gears, and alloy axles.
So driving around, started getting some posi-burps around slow turns, and was like, what? No. Really!?! And started thinking to myself, 'What was the ONE thing you didn't go through on this build?' . Yup. The rear.
So then I started thinking, nah, that thing's kind a fresh, it should be good! And then started back-tracking mentally on just how long about I got the rear. Uh. Wow, looks like it might be, um, 2003? 2004? Dang.
Guess I will be rebuilding the rear, like I don't have 50 other projects I need to get done! Heheh!
So grabbed a 20 ton press from harbor freight, sold my old one due to space constraints, cheaper to buy a press than to farm that crap out.
Will get the RaTech pinion depth tool, the RaTech crush sleeve eliminator setup (smart sleeve), and just rebuild that thing. Dam. Really hadn't planned for this, but guess that's the way a hot rodder's life goes!
http://www.ratechmfg.com/pinion%20setting%20tool.htm
http://www.ratechmfg.com/smart%20sleeve.htm
Still need to swap the upper control arms and front springs, charge AC, and a bunch of little stuff, but at least I'm driving it!
  #233
Old 09-14-2020, 07:57 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I would expect a Moser built rear to last almost forever, how hard did you beat it?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #234
Old 09-14-2020, 12:05 PM
Um. Hard. As much abuse as you can imagine with street tires. But it was like over 4+ engines. A lot of N2O, and think I replaced the ring and pinion once, can't quite recall.
With the 461, it was eating pass axle bearings every 50k miles or so. Housing is straight, it's just that I was pushing it hard. Think it might be the earlier style TruTrac too, which has been updated.
I will go through it, it's time. I can do it for about $1k-$1500 max. Will do u-joints too. It's probably just time.
I will dig out the receipt and check what's in it, and should get an exact date then.
  #235
Old 09-15-2020, 11:10 AM
So looked up the receipt for the rear build, it was in '01. It's time.
  #236
Old 09-15-2020, 11:59 AM
Bob Timmermans's Avatar
Bob Timmermans Bob Timmermans is offline
Cool Spring rate.
"With the GTO endura bumper, the added weight pushed the front springs over the top, and it's sitting too low, and springs are too soft. Ordered some springs from GW when I ordered the upper control arms, but the springs are backlogged to DEC/JAN. Dang. So I ordered some 1/2" pad spacers, which will not only get it off the ground, but also slightly increase the spring rate. I will use those temp until I get the new springs. "
I'm curious about what springrate you'll end up with.
I've got QA-1's up to 650 lbs./inch.
550's screwed all the way up to the end , just about broke the bumpstop loose 1/4"
I read that you're rebuilding the Moser build rear and I kinda agree with OCMDGTO on that.
These are purpose build rears and you pay for that.
They should last , especially with street rubber.
  #237
Old 09-15-2020, 12:37 PM
Well, GW doesn't reveal the spring rates, but I believe the ones I currently have are about 550. The next step up I believe is 620 or 650, but am kind of basing that on previous rates provided by tech support. It's more soft at the moment than I thought it would be, and it contacts the bump stop frequently. I'm tempted to step up 2 rates, but will try the 600s ones first, and if they are too soft, I will put them in the 442.
My 'bird has 720 springs in the front, and under hard driving, it too contacts the bump stops, but it' livable, since it only happens when I really push it.
Don't be afraid to try higher spring rates, even if many say 'it will ride like a truck', it's simply not true. And talk to Doug, let him know what you're experiencing, it will help him zero in on a spring that you will be happy with.
Yeah, '01, that's almost 20 years, stuff doesn't last forever. Like I said, I've had some serious power in front of it, most close to or more than 600hp. The one 400 I had was about 405hp, based on another build I followed, and I was spraying that with a 300hp shot for a while, and dialed it back to about a 250hp shot of N2O.
I get about 100-120k miles out of my engines before I swap them out or rebuild, so it's probably got about 500k miles on it. There was one engine in there, a 455 .060 over, where the crank broke, think that had about 45k miles on it.
I had about 90k on the 461 before I took it off the road for this 'version'. So that too was slightly less than 100k, but that still doesn't drop the potential mile estimate by much.
I had an OE 12 bolt housing for a while in the 90s in this car, that was a brute strength posi unit, and that was professionally built, using heavier springs and vintage NOS asbestos clutch plates. That lasted 10 years, and sold it, pretty sure the guy who bought it is still using it. But he's not making the power I am/was.
I will pull the cover, and look it over, but I'm pretty sure it's going to need a going-thru.
  #238
Old 09-17-2020, 04:47 PM
perry's Avatar
perry perry is offline
Very nice car I finished mine in October 2010
ID:	549796   Click image for larger version
Gold Goat goes orbit orange at pontiacsonline.com
  #239
Old 10-05-2020, 07:46 PM
Wow, I REALLY like that, I was sooo torn on the color, OO was the choice I was struggling with!
So hammering out the details, also trying to catch up on other, non-car related stuff too.
Couple things that are on the list:
* adjust all the glass
* Glove box light and Heater/AC panel light don't come on, pretty sure it's a ground
* Adjust headlights. Need to make sure the LED bulbs are installed facing the correct way too
* Adjust pinion angle, it's pointing down a little, thing the diff was 3.5 degrees when I last checked
* Recalibrate the fuel gauge, again. I get the empty set correctly, then when I go to do the full, seem to always hit the cal button in the wrong sequence. Doh.
* Want to redo the door opening welting, trimmed the one top part a little too much, pops out sometimes
* Rocker adjust. Have about 700 miles on it now, hear a couple that are a little louder than others
* My E-cable clips were a little too small, one fell off, have the correct ones now, need to toss those on
Have a little slop in the steering column lower bearing, will need to address that, once I figure out the best approach. It's a rebuilt/refurbed one, but heard rumors some of the replacement bearings are a little sloppy. Trying to do some homework on that.
Still have some tuning to do, need to take a little break from that, it can be frustrating at times. Pretty sure I need to play with the Injector End Angle settings, have to figure out the best approach there.
Still waiting for the upper control arms, there was a delay due to anodizing the cross shafts.
Anyway, stuff like that, and will have to do the rear once I save the bux for the parts.
  #240
Old 05-06-2021, 01:52 PM
Posting some A/C and heater line routing pics, some were asking about them...
ID:	566013   Click image for larger version
ID:	566014   Click image for larger version
