Old 09-07-2020, 11:16 AM
MUSLCAH MUSLCAH is offline
ID:	548891Here’s my unrestored firewall (67 GTO) ....Pontiac Plant....you can see where the body color goes on the firewall.
  #222
Old 09-07-2020, 05:50 PM
gtospieg gtospieg is offline
Ze... It would seem so. I think it's that way with a lot of the aftermarket parts. One company makes them and everyone sells them and says they fit....kinda like my trunk pan issue.
  #223
Old 09-16-2020, 06:49 PM
Ze...getting back to you about my Tempest...built at the Baltimore plant
  #224
Old 09-16-2020, 06:55 PM
ZeGermanHam's Avatar
Yep, that would somewhat explain the difference. Heck, I wouldn't be surprised to see differences among cars assembled at the same plant but on different work shifts. Manufacturing was different back then.
1998 BMW 328is (track rat)
  #225
Old 09-19-2020, 05:53 PM
Gained an even greater appreciation for body people this afternoon... Took me about 2.5 hours just to mount and align a single door.
The Following User Says Thank You to ZeGermanHam For This Useful Post:
  #226
Old 09-19-2020, 07:26 PM
^^^^^^^^^^^ Patience Grasshopper ^^^^^^^^^^^^^
  #227
Old 09-19-2020, 08:04 PM
Patience, indeed. I was just glad that the donor door (pictured above) seems to fit the body well. The original doors were toast, so I had to source some replacements, which isn't very easy with a post car.
Current dilemma is getting the hinges off the passenger side original door. The bolts are seized, and I'm a hair away from stripping the Phillips heads on them... May have to drill them out.
  #228
Old 09-19-2020, 08:24 PM
nikrnic's Avatar
nikrnic nikrnic is offline
Just got to say I love following your resto story. Big fan of the 24207. It took me years to find the right one. Cheers!
Sent from my SM-G970U using Tapatalk
  #229
Old 09-19-2020, 08:29 PM
Your lucky to live where you do....got rust free parts from near by Idaho...and Cali ...Nevada...with reasonable shipping rates.
  #230
Old 09-19-2020, 09:11 PM
Ze... I recently removed one of the hinges on my Tempest project. I used heat and an impact driver...for a while. I eventually got two out of three and was then able to heat the third one again and use the impact driver again. It finally loosened just enough that I could twist the hinge and then it got easier.
  #231
Old 09-19-2020, 09:17 PM
Yeah, I thought about using heat. It's a good idea and I'd have given it a try, but my torch is elsewhere at the moment. Not wanting to take no for an answer tonight, I got out the drill gun and went to work. I had to drill out four of the six bolts to get the hinges off the original passenger side door, but I won the battle.
Thank you! I hope that others here are able to get some entertainment from my restoration along the way. I always enjoy getting ideas and feedback from others, so it has been fun to post here and share the experience.
Yeah, being from the Midwest originally, I know I have it good where I live now. Even aside from the neighboring states, stuff doesn't really rust in Washington State, either. Much of the state of pretty dry and arid, and West of the Cascades where it rains is still surprisingly easy on cars. Very little to no snow and no road salt makes a huge difference.
  #232
Old 09-19-2020, 09:42 PM
Another tip on getting a good grip on the Phillips head screws....it to add some valve grinding compound to the screw head...then wiggle the Phillips screw driver head into the compound ,until you get a snug fit....then pound away with the impact driver...or impact Gun.
  #233
Old 09-19-2020, 10:31 PM
RedDirtRoad RedDirtRoad is offline
Looking great Karl !
I bought new hinges for my car and have a few sets of original ones if you need a set
Let me know
  #234
Old 09-20-2020, 01:34 AM
bdk1976 bdk1976 is online now
I’ve used this trick with success several times. I think I even used a dab of gojo with pumace once (it worked) when grinding compound wasn’t handy.
  #235
Old 09-20-2020, 11:44 AM
Let me know
Thanks, Dominic! I think I should be able to get by reusing my old hinges, fortunately. They seem pretty slop-free, and thing they appear to need is new rollers and springs for the door brake mechanism on the lower hinges, which I'll replace when I take the hinges back off and clean them up. Fortunately, I see Ames sells the rollers & springs in a kit.
A great idea! Too late for me to try that now, but it's an excellent tip that I will remember for future encounters with stubborn Phillips head bolts.
  #236
Old 09-20-2020, 07:10 PM
Round two on door duty today. Got the passenger side mounted, and it came out very good. Shaved a half hour off my working time from yesterday! I can now breathe a sigh of relief that both donor doors fit the body and aren't going to fight me.
Also quickly slapped on the core support and fenders. They're nowhere near close to being aligned, but I wanted to get them loosely bolted on so I can get to them later in the week. I can tell it's not going to be fun, though...
  #237
Old 09-25-2020, 11:42 AM
Couple questions for you guys. Firstly, I think I know the answer already, but I wanted to ask whether it's necessary to install the front inner wheel housings when mocking up the front clip for panel gapping/fitment testing. I've got the front fenders loosely mocked up now without the wheel housings, and it seems like they might play a role in how everything lines up. Just wanted to double-check before I take everything off and try again.
Secondly, anyone have ideas about these core support bushings? They aren't thick enough to keep the core support from resting directly on the frame. Unless I'm doing something wrong here...?
  #238
Old 09-25-2020, 05:25 PM
I had to shim mine up with washers, as shown in the chassis manual. I'm also thinking that the repro bushings are not as thick as the original ones were.
  #239
Old 09-25-2020, 09:15 PM
Yes... washers as needed
  #240
Old 09-25-2020, 09:31 PM
Washers it is then. Seems a bit absurd to have to stack 3/8" or more of washers, but such is life with aftermarket reproduction parts I guess. Thanks guys.
Anyone have input on whether I should install the front wheel housings when aligning the fenders?
