Old 10-03-2020, 12:23 AM
72redGTO 72redGTO is offline
Default Battery cables
Does anyone know the correct factory lengths of the negative and positive battery cables for a 1972 GTO 455 HO, top post ( spring type ) battery?
Thank you
Old 10-03-2020, 06:13 PM
tripower's Avatar
tripower tripower is offline
The Pontiac parts book I have from 1980 lists the positive cable for all 71-72 A body 455's as 46" (clamp style) and the for the negative, 70-72 T/8's with 455 as 30" (clamp style terminal). Just for reference, it lists the same 46"/30" setup for side post batteries too.
Norm J
Old 10-04-2020, 01:47 AM
Jack Peters's Avatar
My T-37 has spring ring. I know as I has to remove it the second day I had the car. About 250 miles on it. It was the wrong cable or routed wrong. It would stat running when the key was turned off.
JLP
