Old 11-19-2020, 03:52 PM
2nd67GTO's Avatar
2nd67GTO 2nd67GTO is offline
Default Window regulator spring source?
Is there a source for the window regulator spring? I’ve searched with no luck. I’ve rebuilt the power windows and can’t get the passenger window to go all the way up on its own. I replaced the spring on the drivers side and it now works perfectly. I used the spring from a new manual regulator, but would rather not have to spend $90 for a spring.
Thanks in advance.
If it's worth doing, it's worth overdoing!
In the works; 400 based 468 Stroker. 4 Bolt mains, Fully forged rotating assembly, KB flat top, custom ground Comp hydraulic roller, KRE 85cc, 310 CFM heads, FAST multi port EFI.
Old 11-19-2020, 10:23 PM
jmt455's Avatar
jmt455 jmt455 is offline
Can you use the Corvette spring?
https://www.corvettecentral.com/sear...gulator+spring
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1924 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1941 Packard 120 coupe - Factory AC and OD.
1968 GTO, 428, THM400, 2.73 posi cruiser
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
