Old 11-19-2020, 10:40 PM
Hotrodjohn71 Hotrodjohn71 is offline
Default Which spark plugs would you choose?
Group,
I'm my 67 firebird, I have a 1965 326 with a HEI distributor. Which plugs should I use and what gap? Thanks
Old 11-19-2020, 11:23 PM
amcmike's Avatar
amcmike amcmike is offline
Well, if the heads are original to the 1965 engine, AC Delco R45S would have been used and gapped at .035" due to the points.
I'd probably also go one step colder than stock, and use a R44S to avoid the plug being a hot spot that creates pre-detonation when it's not firing.. And since you're running HEI, you could increase that gap to 045" to take advantage of the stronger spark it provides.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
The Following User Says Thank You to amcmike For This Useful Post:
