Old 01-08-2021, 04:35 PM
allenga allenga is offline
Default Wheel Bearing Grease that Does Not Separate and Drip
Hey Gentlemen, I bought the red Mobile 1 grease for my motorcycle and in the summer, it would drip red on my garage floor.
I am doing the wheels bearings on my Pontiac now and don't want any dripping problem. :-)
Do you know of a grease that will not separate like this.
Thank you!
:burnout
Old 01-08-2021, 04:43 PM
68hotbird 68hotbird is offline
Default grease
I have always used mobil shc 220 grease in my wheel bearings in all my cars and trailers and never had and issue with dripping. If your seals are in good condition and the bearings are not over packed with grease you should be good.
The Following User Says Thank You to 68hotbird For This Useful Post:
Old 01-08-2021, 04:49 PM
I mean, the Red Mobile 1 synthetic grease is dripping out of my motorcycle.
Old 01-08-2021, 04:55 PM
redhawk44's Avatar
redhawk44 redhawk44 is offline
220 is a synthetic, as with synthetic oils they are thinner. I've heard of a few guys have leaks when the switched to syn. oil/grease where they had not had leaks prior.
Sent from my Moto Z3 Play using Tapatalk
Let's make welfare as hard to get as Veterans benefits!
The Following User Says Thank You to redhawk44 For This Useful Post:
Old 01-08-2021, 05:36 PM
geeteeohguy's Avatar
If you want the grease to stay put, use Sta-Lube black hi temp disc brake bearing grease. The red synthetic does separate and tend to run. But it stays 'grease' forever and does not harden.
Jeff
Old 01-09-2021, 04:21 AM
lust4speed's Avatar
I had a cartridge of the red synthetic grease sitting on a shelf for probably a year. Had to toss it out because the oil separated out from the carrier. Left a pasty wax residue when I poured the red oil out.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 01-09-2021, 09:28 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Over time I think all of those sticky/tacky "red" varieties separate out some. Every grease gun I've ever outfitted with that stuff that hangs out by the lift needed wiped off before I use them.
I've had the best luck for bearings using Moly grease from TSC. It's not overly expensive and takes the heat better than some of the "tacky" red varieties. I use it in all my trailer bearings and never had a single issue dating back at least 40 years now.
https://www.tractorsupply.com/tsc/pr...SABEgKd0fD_BwE
I'm sure someone makes it for them and it's sold under other labels as well.......
Old 01-09-2021, 10:58 AM
Great forum. I always appreciate the input from you guys.
Old 01-09-2021, 11:07 AM
I've used the red Mobil 1 for 35 years an it ALWAYS separates out. The Wilwood kit on the Camaro with the original Wilwood leather seal let it weep/leak out. Luckily I had an ancient Wilwood rotor that had a rubber seal to get the part # off of that fixed that.
Old 01-09-2021, 11:21 AM
mgarblik mgarblik is offline
X2!! Have had the exact same experience with the separation of the "red" grease in cartridge and tubs. Every time I grabbed my grease gun it had a slippery redish slime on it. Switched to a Valvoline Molly, EP grease. Black tub and cartridge. May be the same stuff Cliff is using from TSC. Valvoline private labels more lubricants than they sell under their own name. The grease is a dark gray/black creme consistency and doesn't separate much. In tub form, I have had to mix it occasionally in the heat of the summer if it sits for months. About the same as Heinz Ketchup that gets that little separation at the top now and then.
Old 01-09-2021, 12:15 PM
The Oreily brand "Ford" moly has done the same in my grease gun too. And heck my tube of white lithium grease always squirts out yellow liquid before the grease comes out.
Old 01-09-2021, 12:27 PM
92GTA's Avatar
92GTA 92GTA is offline
I've tried nearly all of them and now only use the Timken brand grease. It's red, but does not separate.
1969 Pontiac Firebird
Old 01-09-2021, 03:58 PM
Cliff R's Avatar
"Switched to a Valvoline Molly, EP grease. Black tub and cartridge. May be the same stuff Cliff is using from TSC."
Quite likely the same grease under the TSC label. I also use it for camshaft/lifter and engine assembly lube. It NEVER leaves any slimy film on my grease gun either and an excellent product for packing wheel bearings and lubing distributor components during assembly.......
Old 01-09-2021, 04:35 PM
Lucas "Red N Tacky"
Old 01-09-2021, 04:51 PM
If you want to take the time, see if the TSC tub or Cartridge says Ashland, KY anywhere on it. Possibly it will say Ashland oil as well. Valvoline usually identifies their private label stuff that way.
