1969 TA vent tube
Need some help, I need the vent tube that fits in the valve cover passenger side that connects to the lower ram air pan. I have tried Ames, Firebird Central and Year One. No one has the vent tube for the 69 TA set up. They all have one for a ram air firebird but not TA. Does anyone know any other options for me to explore?
I need one also.Tom
That's pretty strange they offer it for the Bird, rather than the T/A
Whole lot more 69 T/A's out there - and being done as clones - than there are actual RamAir 69 Birds. Good Luck to you guys 71 Ford LTD might be usable (sorry , that was a bad joke) |
This isn't the tube?
https://secure.amesperf.com/qilan/De...art_num=FN735L
So long, farewell. |
Unfortunately its not,,,thats actually the one I ordered that doesn't fit
And, you're using the hose too?
https://secure.amesperf.com/qilan/De...art_num=FN735T
Aren’t the lower pans the same in the T/A and the ram air cars?
Yes...bought it the same time I bought the tube and valve cover grommet, The tube is the issue.
Too short then?
I am going to ck it again but it seems too long and its bent for a different hook up. Even the short part that inserts in the valve cover seems odd.
I am going to play with it again about noon. Googling pictures of the engine bay showa a very simple tube with only one bend, looks simple but,,,,, |
Yes it’s the same tube and rubber hose
Mine is close to being right,just not perfect.Tom
Thanks for the pics, let me look at this again and see what I can do.
Appreciate everyones help. |
HELD for Ransom...thanks for all the pics, convinced me I had the most correct one and with a bit of mods I got it to work, I was scared to really twist the tube into the valeve cover very deep for fear of hitting a rocker . Once I saw these pics of an orig tube I just decided to twist and let it almost bottom out.
Thanks again for the help. Is your 69 back on the road? Jim |
They're all scared to make them the best they can be. I don't have one. Pictures are from the barn find 69 thread.
