View Poll Results: Which valley pan do you like best
Butler 1 4.76%
All Pontiac 11 52.38%
Other 9 42.86%
Voters: 21. You may not vote on this poll
Old 02-12-2021, 03:12 PM
Old Goat Racer's Avatar
Default Valley Pan
What pan do you like best ?
Butler or All Pontiac or other
Everybody knows somthin.
Nobody knows everything !
Old 02-12-2021, 04:03 PM
mysticmissle's Avatar
i have 2 pdude/spotts type. they are simple and have held up well to many uses and rebuilds. I did have a nunzi that i believe was made by steffs, that was very nice
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-12-2021, 04:53 PM
tom s tom s is offline
Tomahawk for me.Tom
Old 02-12-2021, 06:51 PM
Scott Stoneburg's Avatar
For a performance application, where no PCV valve is needed I like the AP cast valley pan.
Old 02-13-2021, 12:43 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
The All Pontiac cast pan is the most rigid.
Old 02-13-2021, 12:25 PM
Bill Eveland's Avatar
I have the BOP engineering , its quite thick . After i didnt need the pvc, just plugged the stand pipe with a freeze plug.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 02-13-2021, 12:49 PM
Is the BOP thicker than Butler pan ? They appear similar NO ?
Old 02-13-2021, 01:30 PM
ta man ta man is offline
All Pontiac is rigid..great for R/R.
Name:	new engine pic.jpg
Old 02-13-2021, 09:01 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
I chose this one for my IAIIA build...
Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
The Following User Says Thank You to 69Goat1 For This Useful Post:
Old 02-13-2021, 09:29 PM
GTOGEORGE's Avatar
All Pontiac cast aluminum.
GTO George
Old 02-14-2021, 10:18 AM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
I used the nitemare performance on my street car and it fit great.
The butler pan that I bought for my tall deck block was a waste of $80. Contour was wrong and once i fixed that and went to tighten it down one side falls underneath the head before it is seated against the block. Was told that the bolt holes in the block must be off to one side Lol
Old 02-14-2021, 06:25 PM
TransAm400 TransAm400 is offline
Nitemare Performance on my IAII. Fit really nice. Much nicer than the regular sheetmetal type.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 02-14-2021, 07:07 PM
I'm not sure how thick the Butler one is, the BOP is 1/8"
6.27@107
9.97@131
Old 02-15-2021, 01:38 AM
Dragncar Dragncar is online now
The Nightmare unit looks the best. But they all do the same thing.
I had one of those old finned cast pans, Moon I believe. Sent it back to Dan Whitmore. It was there so long I forgot to ask for it when I got my engine back from his widow.
Wade at BOP bought it when she sold his stuff, he lives close by.
Wade has it on a static engine display. Very cool, my old valley pan, cast finned valve covers, RAV heads and a mechanical injection intake. All very rare.
He sent me a pic of it, I will see if I can dig it up.
Old 02-15-2021, 06:14 AM
I have a Moon finned pan on my 535. I had to modify the water cross over to fit.
Old 02-15-2021, 06:39 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Thank you for posting that. That looks like a very nice piece. I’ve been looking for one of those for quite a while. Good to know nitemare makes them. The reinforcement looks cool and the pan itself looks like you wouldn’t have to modify the water crossover if the heads/intake were decked.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 02-15-2021, 01:20 PM
69Goat1's Avatar
It’s the nicest valley pan I have ever used. It fit perfectly and we modified nothing for the VP.
Old 02-15-2021, 08:46 PM
BILL BOWMAN1's Avatar
Kauffman
Old 02-16-2021, 02:36 AM
You know how much those things are worth these days ? I seen 500$ kicked around.
Not sure if I would have cut on it. Mine hit the bottom of my intake so I sent it to Dan to get his opinion.
Nice looking engine at any rate.
Old 02-16-2021, 11:17 AM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Anyone have suggestions for adding a PCV to the Indian Adventures pan correctly?
