Old 03-06-2021, 06:14 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Printing is being done in pieces and will be glued together.Couple of pieces.
I think the "tub" and top will be done this week.Looking forward to checking the fit.Baby steps!Tom
Ah, didn't realize you were doing that, nice way to get it done on a small printer, looks great, best hopes for a nice fit.
Just look at that part number would ya ! Thanks for the update Tom ! Now I'ma have ta go change ma skivvies ...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
  #102
Old 03-07-2021, 04:22 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Default Bathtub
Thanks Tom looks very impressive so far. Thanks for doing this. Mike
  #103
Old 03-07-2021, 06:38 PM
ANDYA ANDYA is offline
Tom, it looks like your getting this project done at an amazing pace. The Pontiac community is lucky to have you on our side. Can't wait to see the fully assembled 3D model.
  #104
Old 03-08-2021, 08:39 PM
tom s tom s is offline
Jim Robertson performed his magic doing the late style changes that had to be done to make it fit a set of 69 heads.Tom
ID:	562325   Click image for larger version
ID:	562326   Click image for larger version
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #105
Old 03-08-2021, 08:56 PM
tempest1964's Avatar
That is a beauteous thing. Well done sir!
  #106
Old 03-08-2021, 08:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks great!!!
Go fast, see Elvis!
  #107
Old 03-09-2021, 06:57 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Amazing!
  #108
Old 03-09-2021, 07:44 AM
mysticmissle's Avatar
wow, that's an amazing amount of progress in a short period of time. You truly are a contributor to keeping Pontiac History alive and interjecting some nostalgic future!
  #109
Old 03-09-2021, 08:45 AM
sdbob sdbob is online now
Thank you. Amazing.
  #110
Old 03-09-2021, 09:59 AM
JSchmitz's Avatar
Smile
Can't wait to see some dyno action from this baby!
  #111
Old 03-09-2021, 11:43 AM
Dyno numbers have been out for years.About 30 HP over a dual plane 800 CFM single 500plus HP engine.Tom
  #112
Old 03-09-2021, 12:25 PM
WOW,at this pace we might see some of these manifolds at Norwalk this year. Amazing progress to say the least!
  #113
Old 03-09-2021, 12:34 PM
JSchmitz's Avatar
Got ya. That's impressive gain. Does this have some design improvements though?
  #114
Old 03-09-2021, 12:38 PM
Has a V plenum,when I tested the diff designs before there was only about 5 HP diff between all 3 on a 462 HiPo street Eheaded engine.Im sure with a high RPM race engine and ported to match it will be better.Tom
  #115
Old 03-09-2021, 01:02 PM
mgarblik mgarblik is offline
Great progress Tom. When I get my intake, (I didn't say if), I will dyno my combination for sure. Very optimistic about how this is moving along.
  #116
Old 03-09-2021, 01:10 PM
Looking really Nice Tom.
  #117
Old 03-09-2021, 03:49 PM
slowbird's Avatar
slowbird slowbird is offline
Sorry if i missed this info, but how long are the runners, port runners height and width at plenum? Will ports at flange be stock or ra4 sized?
  #118
Old 03-09-2021, 08:25 PM
This link from b-man might help with parameters.
Pictures and measurements in this thread:https://forums.maxperformanceinc.com...hlight=Bathtub
Tom will have to chime back in on intake flange port size for the Early & Late versions.
i'm thinking probably standard/stock D-Port since he is trying to get factory part numbers into the casting for (potential) governed events use.
  #119
Old 03-09-2021, 09:38 PM
Ports have been reduced down to stock size ports with room to make bigger.When I get the intake back I will give you the numbers on the runners.Tom
  #120
Old 03-09-2021, 11:50 PM
tooski tooski is offline
On top of the evident bling factor, how would this race type manifold with dual carbs affect the performance of a 'healthy' 400? I would suspect the over carburetion would detract from the performance. What was the original application for them?
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
