Old 03-10-2021, 07:48 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Default 1969 gto brake line help
I'm finishing up installing my new brake line kit I purchased from inline tube as well as the distribution block I purchased from them and ran into a snag. The rear brake line uses a 1/2-20 fitting going into the back of the block but the block itself is larger then 1/2-20. Anyone know what adapter I need to get this plumbed? I purchased the correct disc brake distribution block and line kit from the same company so I assumed it would fit, Guess I should have known better lol.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 03-10-2021, 07:52 PM
n20ta2's Avatar
Here is a shot
Old 03-11-2021, 07:29 AM
n20ta2's Avatar
So it seems the bock I bought is for a 70 and the only difference I believe is a different output for the rear brake line. Maybe 9/16? It's bigger then 1/2
Old 03-11-2021, 02:26 PM
Scott Thelander's Avatar
I can help with a nice original 69 if you have a need
Scott
Old 03-11-2021, 06:01 PM
n20ta2's Avatar
Thanks, I still have my original but figured a new one would be nicer. I think I found the correct adapter, I'm going to pick it up tommorow
