Old 04-15-2021, 12:40 PM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Default TKX from Silver Sport
I just ordered a perfect-fit TKX kit for my 69 GTO. They say I should be getting the transmission by the end of May.
I guess I'm going to have to dial in the bellhousing now.
I have a question about the Browell Tool. How do you tell the far off-center you are if you have a no-go situation? Do you use a feeler gage?
And while I'm at it, does anyone have a Browell Tool that they would like to rent out?
Thanks!
Old 04-15-2021, 07:57 PM
TB1's Avatar
TB1 TB1 is offline
Thanks!
I used Browell tool and a feeler gauge to figure out how much it was out and also used the same feeler to figure out the starting and end points of the run out. Mine was out .014" from about 8 o clock down around to 4 o clock. I Bought the .007 dowel pins from Robb Mc and installed them. I also double checked this with a dial indicator to verify I was doing it right.
It mentions in the TKX instructions to verify the parallel measurement of the bellhousing as well radial run out of the bore both have a max of .005", this was a giant pain in the ass and required some shim stock to get the factory bell within spec on my car.
Start with the parallel measurement once dialed in then move on to the radial run out keeping track of the shims and locations between the bellhousing and the block. If I had to do it all over again I'd just use the dial indicator. The Browell tool is great if your not concerned with the parallel measurement of the bellhousing face, It must be an issue if they mention it or maybe a CYA type thing for warranty.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 04-15-2021, 10:08 PM
gtospieg gtospieg is offline
What TB1 said...use a dial indicator and check for parallel first then concentricity...no need for that other tool.
Old 04-16-2021, 11:16 AM
6T9GTO's Avatar
Thanks guys. I decided to use the dial indicator because I need that for the parallel measurement anyway.
Old 06-15-2021, 01:13 PM
6T9GTO's Avatar
Well it's her now. I guess I got to get that bellhousing indexed...
The Following User Says Thank You to 6T9GTO For This Useful Post:
Old 06-15-2021, 01:21 PM
tom s tom s is offline
I have done a few Tremics now and have not had to do anything when using a stock bellhousing.The first one we used a after market and it needed some tweaking.FWIW,Tom
Old 06-15-2021, 01:23 PM
6T9GTO's Avatar
Thanks Tom. I am going to check it this weekend.
Old 06-15-2021, 01:28 PM
6T9GTO's Avatar
Old 06-15-2021, 10:41 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Very nice. Looking forward to updates!
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 06-16-2021, 01:00 AM
pokey1 pokey1 is offline
Yup looking very nice. should be an easy install and make a whole different driving vehicle. Mine is night and day difference.
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches..
Old 06-16-2021, 10:03 AM
David Jones's Avatar
My Quick Time needed offset dowels. I used RobbMc.
Old 06-16-2021, 01:46 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Just got word….. my trans gets shipped out tomorrow!!!
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 06-17-2021, 12:51 PM
6T9GTO's Avatar
67GTONUT are you using your original bell housing? I am interested in your runout numbers.
Old 07-26-2021, 12:46 PM
6T9GTO's Avatar
So, when I measured the bellhousing runout, I came up with .014". I ordered the offset dowels from Robb McC.
I don't know how many of you have removed the dowel pins with the engine in the car, but let me tell you this was a complete pain in the a$$! No room to drill the pins and tap because of the floor/ trans tunnel.
I ended up running a 5/8" die (hexagonal exterior shape) on the pins and threading them. I used the hexagonal shape because I could turn this with a socket and ratchet. After threading the pins, I used a stack of flat washers against the block and screwed a nut on the pins. This successfully pulled the pins from the block.
Now to re-measure with my offset dowels. Then on to actual install of the transmission.
The Following 2 Users Say Thank You to 6T9GTO For This Useful Post:
Old 07-26-2021, 03:29 PM
65madgoat's Avatar
Contact JODY TRANSMISSION to get parallel aligning shims for $79 - he will even refund you if you don't need them. But a must to check and likely needed. And ditch that Browell alignment tool.
I tried getting dowel pins last week from RobbMc but he is out. Jody has them in stock and doesn't charge $20 extra for a set like other shops. And Jody is the most knowledgeable and helpful transmission guy around.
Jody's Transmission
(610) 413-8015
jodystransmissions@verizon.net
Old 08-01-2021, 11:39 AM
6T9GTO's Avatar
Pilot bearing problem.
When I remove the pressure plate, I was able to pull the pilot bearing out with my finger.
The new pilot bearing, # 7109, is the same way. Is there any way to tighten the bearing in the bore? I have heard of using a punch in a few spots on the side of the bore. I have also heard of having the bearing knurled.
What would you guys do?
By the way, when I last installed a new clutch in the car, I did not notice the pilot bearing being a problem, but that was a few years ago and my memory ain't what it used to be.
On the bright side, my runout is .001!
Thanks in Advance!
Old 08-01-2021, 02:13 PM
If you're using the bronze bushing you can get one with a larger outside diameter and have it turned down to whatever size you need.
Old 08-02-2021, 03:30 AM
67GTONUT's Avatar
Yes, stock bell housing
My guy has not gotten that far yet...... getting flywheel cut then reassembly begins!!!
Troy
Rockaway NJ
67 GTO
Old 08-02-2021, 08:34 AM
Bronze ones you can stake with a punch.
Old 08-02-2021, 09:02 AM
There are larger OD needle bearing style pilot bushings out there for Pontiac and other applications.
I wouldn't recommend using the typical bronze bushing with the Tremec trans. It uses a tapered input bearing that requires precise location of the input and is not very forgiving, which is why dialing in the bellhousing is so important with these transmissions. Muncie just uses a regular ball bearing for input support so it's not critical.
https://youtu.be/XqEydRRRwqE
