Old 04-21-2021, 05:33 PM
John Milner's Avatar
John Milner John Milner is online now
Must be something new because 25 years ago the L2257 TRW 428 piston was a flat top.
I had to machine a dish in them, which ended up being 16cc. Then zero decked the block, or close to it (.004" in the hole) and with a .038 gasket and a 76cc head I had 9.7:1 compression.
Ran that engine for a couple decades on pump gas.
No, nothing new. Strange that yours were flat tops originally as I've had several sets of the L2257's and each set has had the dish. I have a set of L2257's in my '66 421. They had a 13cc dish in them just like my 2282P's which I run in my '65 421.
I did not have a closeup picture of the L2257 number on my pistons in my 421 but found one on the forum that I attached. The 2282P pistons is a set that I have sitting on my shelf for a future build.
ID:	565156   Click image for larger version
ID:	565157   Click image for larger version
ID:	565158   Click image for larger version
  #82
Old 04-21-2021, 07:03 PM
Yep those are different than mine were.
https://youtu.be/XqEydRRRwqE
  #83
Old 04-21-2021, 08:43 PM
racerboy's Avatar
racerboy racerboy is offline
Originally Posted by John Milner View Post
L2257 and 2282P forged Speed Pro pistons have roughly a 13cc dish. I run several 428's with these pistons and 72cc heads on pump gas.
Thanks John. Those pistons look just like mine. I ran my 670s on this engine for something like 5000 miles and I don’t recall any pinging, but that was more than 7 yr ago. The cc kit I bought from Jegs came today so I am still going to cc the heads, if for no other reason than to do something I’ve never done before, but it sounds like I should be able to just put these heads back on and run them until my 400 is done. Hopefully. Saves me the $ of buying another set of heads. I guess I still will have to decide which cam is best.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
  #84
Old 04-21-2021, 08:47 PM
racerboy's Avatar
FJ
I found a set for sale and you can see that they came with the small dish and 4-valve reliefs. I don’t recall the machine shop adding any dish to my pistons, but is has been almost 20 yr.
https://egge.com/part/egg-1000-l2257-8/
  #85
Old 04-21-2021, 08:49 PM
racerboy's Avatar
Default Best cast iron heads for 428 street build
  #86
Old 04-21-2021, 09:08 PM
tom s tom s is offline
For a little more you can get a custom piston with the correct dish for what ever head you want to run.I just did 2 428s with Autotec pistons.Tom
  #87
Old 04-21-2021, 10:26 PM
Yep those are different for sure.
I haven't seen the combustion champers on a 670 head in a long time, but the 13's I used for that combo don't have much quench area. In fact most of the quench is around the parameter of the chamber as you can see in this picture. So I didn't need a fancy "D" shaped dish to take advantage of a big flat area, these heads didn't have enough of that to worry about. In fact the ring I created with the bowl style dish was wide enough to take advantage of most all of it. Plus I could create the CC needed with the added area instead of making a smaller D shape deeper to gain CC and possibly making the piston weaker, there is only so much meat to work with.
Name:	#13 head checking comb chamber CC.jpg
  #88
Old 04-23-2021, 02:02 PM
racerboy's Avatar
FJ
I am about to cc my first combustion chamber. Do I need to put anything down to seal the plexiglas to the head, or just let it lay flat?
  #89
Old 04-23-2021, 02:16 PM
A little Vaseline will seal it up.
  #90
Old 04-23-2021, 03:01 PM
racerboy's Avatar
Thanks b-man. I used a little film of grease. The smallest chamber came out around 73.5. The others were between 74-75.
  #91
Old 04-23-2021, 03:34 PM
MarkS57's Avatar
MarkS57 MarkS57 is online now
There could be a flat top version, TRW had flexibility years ago with compression ratios. My stock 69 428 had the smaller dish in the factory pistons.
65 Tempest, 400, TH400
86 Fiero SE 2.8
  #92
Old 04-23-2021, 03:38 PM
lust4speed's Avatar
Both valves look to be about even with the floor. Any problem with the measuring fluid seeping past the valve seats?
Mick Batson
  #93
Old 04-23-2021, 04:54 PM
77 TRASHCAN's Avatar
LOL, your garage looks a lot like mine
Shut it off
Shut it off
  #94
Old 04-23-2021, 05:13 PM
There are a few small trails to walk through. They fill up quickly as I’m sure you know.
  #95
Old 04-23-2021, 09:05 PM
racerboy's Avatar
I didn’t notice any seepage. This is the first time I ever cc’d anything.
  #96
Old 04-23-2021, 09:27 PM
racerboy's Avatar
Do you think I can run these heads as is or should I look for a set of 6X-4 heads with bigger chambers.
If you think I’m ok compression wise, would you re-install the XE274 cam or switch to the Crower. If I don’t use the Crower I am going to sell it. Several forum members have contacted me about it.
  #97
Old 04-23-2021, 10:45 PM
Jay S's Avatar
Jay S Jay S is offline
If your panning on running 93 octane just put it back together as it was. For 91 octane I would swap in the Crower and run the 670s. 87 I would look for the 6x-4s and keep the XE. Sell the Crower and lifters. 670s aren’t bad property either, appear to be a good set of 670s.
  #98
Old 04-25-2021, 12:50 PM
racerboy's Avatar
Thanks Jay. Is there any specific head gasket thickness I should run, or should I just get a regular old Fuel-Pro engine gasket kit?
  #99
Old 04-25-2021, 02:31 PM
Jay S's Avatar
My preference would be to use the standard 8518 perma-tech felpro.
  #100
Old 04-25-2021, 07:26 PM
racerboy's Avatar
Another question. When I built this motor back in 2001 or so, I went with the aftermarket SFI damper. If I chose to, could I just substitute this with a stock balancer? I could never seem to get the belts to be perfectly aligned, even when I used the adapters.
