Old 05-03-2021, 01:18 PM
GTOGEORGE's Avatar
Default SCE copper head gasket
I pulled my cylinder head off to re-lap a intake valve in, when putting head back on I noticed that the head gasket had stretched. Wouldn’t go on the pins without bowing gasket.......what’s up with that?
GTO George
Old 05-03-2021, 03:35 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
My SCE gaskets did all kinds of stretching in its short life...I am basically having to completely rebuild my brand new engine now and will never use a copper gasket again no matter what.
Old 05-03-2021, 04:57 PM
GTOGEORGE's Avatar
WOW........ive never heard of a copper head gasket stretching, I've used a lot on my engine (SCE copper) and not one did that..........guess I can't say that anymore!
GTO George
Old 05-03-2021, 06:22 PM
tom s tom s is offline
I had a issue with a set of custom SCE copper gaskets.Made to use as a hybrid with reg pontiac heads on a 301 block.The fire ring was like 51 thou thick and the gasket was like 42.NFW that firering would compress enough to seal the gasket.$650 for the dyno,250 for the gaskets,no idea of the breakin oil etc,we ended up with a flood in the dyno room,water in the oil etc.Complete tear down.Sucked.Last time I use them.Tom
Old 05-03-2021, 07:22 PM
GTOGEORGE's Avatar
I already ordered another set, next year I’m looking into a fire ring set up!
GTO George
Old 05-03-2021, 09:12 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
http://www.naiser-racing.com/
George these guys can set you up
Old 05-04-2021, 12:07 PM
GTOGEORGE's Avatar
GTO George
Old 05-04-2021, 12:55 PM
You said next year you’re looking into a fire ring set up, I said these guys can set you up. I’m not sure what the ? Is about
Old 05-04-2021, 01:04 PM
GTOGEORGE's Avatar
OK, just wanted to make sure.......thanks.
GTO George
Old 05-05-2021, 05:26 PM
taff2's Avatar
taff2 taff2 is offline
I used Hussey's copper gaskets and didn't have any stretching or bowing of the gasket, .055" thick gaskets with steel wire O rings, just 18 psi of boost though, up to 220f coolant temps at one point.
Yours are probably getting hotter than you think ,or unevenly heated/cooled.
Old 05-05-2021, 06:18 PM
George do you monitor exh temps?
Old 05-05-2021, 09:01 PM
GTOGEORGE's Avatar
One on each side.
GTO George
Old 05-06-2021, 02:20 PM
mgarblik mgarblik is offline
We had a few minor issues with a set of Clark Copper. I have never used SCE. The Flattout rubber coated copper were great and stayed in shape and sealed very well for us.
