| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
I'm interested in it and I'm sure others are as well. I'm gonna build an LS engine one of these days. Whether it goes in my Pontiac or not it undetermined as of now.
'65 Tempest 467 3650# [email protected] |
I appreciate the interest! Good luck with your build!
I will tell you that J.W. Performance Transmissions was very nice about the whole thing. They offered to replace it or re-machine the part. I will try to do it myself likely.
I really like the ball and flange collectors! I had to ding the passenger floorboard a little to clear the O2 sensor. Probably should have taken the header off and tweaked the bung. Oh well, hit the easy button instead.
Just installed ICT Billet brackets for alternator, PS pump, and tensioner. They are top notch! Only minor gripe is positive stud is very close to oil filler neck on valve cover. Will cut stud down accordingly. Haven't bought PS pump yet. Have new GM pulley though.
Did they understand you were mating to an LS engine? Is it the correct part in other words...
Damn! This should NOT make a difference in terms of the flex-plate interference. Next time I have it out, I'll weld a tab on the top. NBD.
J.W. confirmed that the only difference is that the LS model comes with metric hardware and the extra bolt tab. So I'm good.
Looking good. Keep up the updates.
Thanks! Will do.
I just started taking all of the wiring out today. Gonna be a while... |
Nice work!! Looking good. Power Steering. I used 98-2000 f body pressure line. Just had to replace metric end with oem flared end. Tweek the hard line section to line up at gear box. Easy!!
Steve 71 Pontiac GT-37 400 4 spd (sold) 71 Formula 400 turbo 400 (sold) 01 Firebird T/A WS6 auto (fun) 64 Tempest Post car LS1/4L60E (Love It!) 65 Lemans Post car LS1/4L60E (More Fun)(sold) 73 Lemans GT 400/auto 1 owner 52k miles 69 El Camino LS1/4L65E (Awesome) 70 Pontiac GTO Convertible 400/400 Original (sold) 69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569 72 Post Coupe GTO 400/400 1 of 60 built 1 owner original |
I installed an F-body high pressure hose like suggested. Not thrilled with how it looks. But will work for now.
I couldn't take the factory style pressure line. I Fabbed one with Russell Powerflex and associated AN fittings.
I chipped the first POS plastic pulley when I was tightening the pressure hose. Barely bumped it. Had to cut it off. Puller ripped the flange off and it still wouldn't budge. Bought a new one. It wouldn't press on. It seized up just short of going on all the way. Ugh! I bought a billet pullet this time, Put the pump in the freezer overnight. Put the pulley in boiling water. Greased the shaft real good. Went on like butter! School of hard knocks in session again.
Then I decided to test the system before firing the engine. Cut the head off of a bolt and used a drill to spin it. Works perfectly! No leaks. Turn the input shaft by hand since the steering column is out. Lock to lock smooth as glass. |
Perseverance wins again. Good work
Perseverance and cash lol. Thanks!
The pump pulley is meant to be a dry interference fit to keep it on the shaft. Using grease on the shaft is questionable. The pulley may come off easy as "butter" too. JMO
Made some more progress. Fuel lines are done. I pressure tested those to 100psi. Installing 1/2" & 3/8" stainless lines was not fun! Is overkill. But planning for much more power later on. Had to replace the Strange master cylinder that was leaking.
