Old 05-07-2021, 10:26 PM
Billz428's Avatar
Billz428 Billz428 is offline
Question Swap cam while motor is In ?
Is it possible to change the Camshaft out while engine is in the car ?
1980 TA
Thanx for any help here .
http://www.youtube.com/watch?v=DtKk5GNtWH0
Life is tough. Life is tougher when you're stupid.
-John Wayne
Old 05-07-2021, 10:31 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Yes, the hood latch support bar will need to be loosened and pushed out of the way. If the car has AC the condenser will need to be moved around but shouldn't have to be disconnected.
Go fast, see Elvis!
Old 05-08-2021, 12:27 AM
Billz428's Avatar
Thanx, this eases my mind .
-John Wayne
The Following User Says Thank You to Billz428 For This Useful Post:
Old 05-08-2021, 05:56 AM
ErikW's Avatar
ErikW ErikW is offline
Absolutely
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 05-08-2021, 06:06 AM
If your doing it on your own then do yourself a big favor.
Get some Mechanics wire and slip it in some vacuum hose or fish tank tubing, form it into a loop up so you can slip it over the end of the cam to support it as you progressively slip it all the way in.
Also once you remove the old Cam take a good look with a mechanics mirror at all the old bearings to look for signs of them coming as they tend to do at times,
Old 05-08-2021, 08:25 AM
GTOLou GTOLou is offline
Did this in a 2nd gen this past spring. I remember having to move the center crossmember/hood last deal.
I think a screw in cam install tool helped too.
Biggest pita was getting it timed/degree'd and messing w/ a snug .005 timing set. Dropped a sims - shim into from of pain. Magnet and patience found it (Make sure you stuff rags in front lip of oil pan - I had done that, but somehow it got past).
Put in the older Ole Faithful per Dave's recc for my motor. My timing set allowed 2 degree's per adjust. I could either leave it retarded 1/2 degree or advanced 1 1/2. I went advanced...I figured once the timing set was broken in I'd lose 1/2 degree + anyway.
455/76 TA. Its a beast. Take your time. Somewhat of a pain to do in car. Use the right cam..lol.
Old 05-08-2021, 09:08 AM
Non-AC is easy.
With charged AC is impossible.
Old 05-08-2021, 09:18 AM
What he said. Did about 4 cam swaps motor in the car in the 78 TA.
A crank socket with a degree wheel on it is easy to use also.
Old 05-08-2021, 09:39 AM
I can’t see how it can be done with A/C without disconnecting the condenser!
Old 05-08-2021, 09:42 AM
Formulas Formulas is offline
I have even changed out 4 out of 5 cam bearings in my 70 bird in the engine bay about 15 years ago now
Old 05-08-2021, 12:17 PM
Steve there is enough room to just unbolt the condensor and enough slack in lines. Just need a little room there is all. Biggest deal is the latch brace. But all the swaps I was doing I pulled mine.
Old 05-08-2021, 03:16 PM
Billz428's Avatar
Car has A/C removed long ago.
Next week.i start this adventure .
Thanx Everyone .
-John Wayne
Old 05-08-2021, 03:24 PM
Note that as soon as you get the timing cover off if the 2 lower bolt hole sleeves are not in the cover, but still on the face of the block do as posted above, pack the open nose of the oil pan until it’s overflowing with paper towels and then remove those two guide sleeves.
Form-a - gasket them in lightly into the timing cover so they do not fall out during reassembly and fall in the pan when the paper towels are no longer there!
Old 05-09-2021, 10:16 AM
And keep the pan packed until the timing chain goes on-be sure the cam key is a tight fit! Ask me how I know-luckily a skinny magnet retrieved it!
Old 05-18-2021, 04:01 PM
Billz428's Avatar
Way loose Chain.was found .
Had been line honed .
4 bolt caps installed.
a standard timing set had been installed .
Maybe 8 tanks of gas, cruzing
Going forward to.the New Lunati grind .
Lots of slop.
-John Wayne
Old 05-18-2021, 04:07 PM
Billz428's Avatar
Exclamation
Found this .
-John Wayne
Old 05-18-2021, 04:08 PM
Billz428's Avatar
Tried to.post a video
-John Wayne
Old 05-18-2021, 04:12 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Done that a few times.
Old 05-18-2021, 05:41 PM
Billz428's Avatar
https://m.facebook.com/story.php?sto...&id=1415474368
FB video
-John Wayne
Old 05-18-2021, 05:43 PM
Billz428's Avatar
Exclamation Sloppy chain
Found this .
-John Wayne
