Old 06-18-2021, 10:32 AM
tjs72lemans tjs72lemans is offline
Default Rally wheel painting
For those who have done this. Once the silver is sprayed, how long do you wait to apply the taped inserts to spray the charcoal paint? I don't want to pull the silver off and I don't want the charcoal to lift and do want it to stick. I've painted with spray cans before and they usually list recoat times. The paint from Inline Tube doesn't specify.
Old 06-19-2021, 07:25 PM
400 4spd.'s Avatar
Give it 24 hrs. If it pulls off it wasn't prepped well. I always spray the center charcoal first. Easier to mask the charcoal than all of the silver.
The Following 2 Users Say Thank You to 400 4spd. For This Useful Post:
Old 06-19-2021, 08:43 PM
Am I confused? I thought the only thing silver was the was the 5 spokes. The rest on mine look to be sprayed charcoal. I could swear I read somewhere, where it states to spray wheel silver, apply vinyl spoke stickers and paint charcoal.
Old 06-19-2021, 09:19 PM
Ok. Mine are silver around outside rim. It seems easier to spray silver, apply my vinyl decals on spokes, mask outside rim area and spray charcoal.
Old 06-20-2021, 08:40 AM
mrennie's Avatar
mrennie mrennie is offline
Also interested in this as I am close to painting mine, and have purchased the Inline paint as well.
I believe the Inline spray cans are lacquer, which should result in quick drying and recoating anytime...hoping this is correct.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 06-20-2021, 09:42 AM
78w72 78w72 is offline
most rallys should be painted all silver then just the insides are painted charcoal. that allows for no trim rings like many early ones were & to me looks much better without trim rings. i think later years that use trim rings they started only painting the spokes silver because the trim rings covered most the rim.
depends on the paint being used for for cure time to apply masking, ive never used inline paint so cant say for sure but with other brands of actual wheel paint in a can that is fast drying i let it cure for about 30 minutes to 1 hour & lightly applied the masking, i did my own masking & cut the edges with a razor blade but the templates work too. many paints have a specific small window for recoating or you need to wait 24-48 hours & lightly scuff to recoat. i would call inline to ask about cure times before just guessing if theres no instructions on the can.
another trick i use that a long time painter taught me is that after you spray the silver (or whatever color) & put the masking on, push the edges down firmly with your fingers & then spray a light coat of silver around the edges of the masking, that gets that same color under the edges so the next color doesnt bleed under the edges. works great on the rallys ive painted.
Old 06-20-2021, 10:22 AM
400 4spd.'s Avatar
My mistake, as I mask mine with Fine Line and tape, not the vinyl cut outs which require spraying silver first. I tried those once, and they weren't that great a fit for me.
ID:	568511   Click image for larger version
Old 06-20-2021, 11:13 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
X2 with 400 4spd. I always painted the Grey first since it's a lot less to tape up. 24 hrs to mask w 2" tape and cut with a razor blade. I need to repaint mine now as a matter of fact. 400, those rims look fantastic!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 06-20-2021, 11:51 AM
The tape time is what I was worried about. Don't want to pull the silver off after the charcoal is painted. But, didn't want to wait too long so charcoal paint doesn't stick to silver or lifts. I've had issues with lift and wait times with other spray paints. Trying to avoid that. Rims should be back from blaster tomorrow for prime and paint. I'll call Inline.
Old 06-20-2021, 12:01 PM
MUSLCAH MUSLCAH is offline
Yup …fine line tape….no cutting tape with a razor blade…that just gives rust a head start
Old 06-20-2021, 02:01 PM
I've just used the 'ol ebay masking kit, and the paint is easy to find at virtually any auto supply store. Not factory by any means but acceptable to me. I waited a couple of days before spraying the charcoal I just wanted to be sure that it was good and dry.
Interesting about spraying the charcoal first. I don't know that I would have the patience or the talent to acheive something that I would be happy with.
Old 06-20-2021, 05:06 PM
Ya, I'm not sure where a razor blade comes in for cutting. Spray silver, then tape the outside of rim edge to spokes and tear the tape tail. Then stick the vinyl to the spokes and spray the charcoal. Seems easier than taping all the inside that would've been sprayed charcoal first too.
Old 06-20-2021, 07:26 PM
The first wheel ain’t bad to tape off….the other 3 suck
Old 06-20-2021, 08:02 PM
400 4spd.'s Avatar
I can line up a set and it takes me 45 minutes per wheel to mask for the second color.
Old 06-20-2021, 08:14 PM
Is that all your guys let you do now a days ….lol 😄
Old 06-20-2021, 09:11 PM
mrennie's Avatar
I'm painting seven...4 + the spare + 2 for drag radials.
Not looking forward to it.
Michael
Old 06-20-2021, 10:13 PM
400 4spd.'s Avatar
I wish. In fact I'm going to take advantage of them being on vacation so I can work on the body restoration of my Sting Ray.
Old 06-21-2021, 09:34 AM
burd's Avatar
burd burd is offline
There’s a guy in the area that does snowflakes, ( Mongo) I’m sure he’d do rally’s. I’d just drop them off. Pita painting
Old 06-22-2021, 08:34 AM
The next set l do will be charcoal first.. l like that idea.
Never used the masking kit. Just a combination of different tapes and masking paper.
Sent from my moto g stylus (2021) using Tapatalk
Old 06-22-2021, 11:15 AM
Inline tube says wait 72-96 hours before tape/repaint. Wow! Now I wonder if I have to scuff first coat to get second color to adhere correctly.
I called Seymour and had to leave a message. Their tech sheets say nothing.
