Old 07-07-2021, 03:23 PM
whittp whittp is offline
Default Which crossmember for 67 GTO convertible with TKX?
The car is in the shop getting it's TKX swap. What crossmember works? It currently has an aftermarket unit designed to work with the overdrive transmission that was installed.
Old 07-07-2021, 03:42 PM
David Jones's Avatar
According to a quick search of the archives, the factory cross member works but a couple of holes need to be drilled.
When I did my TKO, that was also the case.
Old 07-07-2021, 04:43 PM
Thank you very much I'll get one on order.
