Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-05-2021, 07:24 PM
gem66 gem66 is offline
Default 1977 Pontiac 400 parting
Do you need anything from a stock 1977 400? Its a 557 block stock bore, will need machined to cleanup some rust in the cylinders, with 6x-8 heads, 4 barrel intake, quadrajet carb. Standard crank and main caps. Totally disassembled. Crank turned fine, very little wear on bearings. Good for stock build, nothing high power. $300.00 for everything or tell me what pieces you want with an offer plus shipping.
Will not ship the big stuff.
1970 Firebird 3200lbs - CVMS built, pump gas 461, 3.89 gear 29.5x10 inch tire,... 10.40 @ 129mph.
Old 07-08-2021, 10:21 AM
TA76's Avatar
TA76 TA76 is offline
Willing to ship the 6X-8 heads?
Old 07-09-2021, 07:58 AM
If you pay the freight, sure. Those things are heavy!
Old 07-09-2021, 09:26 AM
78w72 78w72 is offline
check with fastenal, best rates for shipping blocks & heads etc. just strap to a pallet & drop off at their loading dock. then buyer picks up at their local fastenal store.
Old 07-09-2021, 07:20 PM
HoneyHush HoneyHush is offline
How much do you want for q-jet?
Old 07-10-2021, 07:02 AM
Any reasonable offer with shipping from zip code 22923 to you. I would consider it a rebuildable core.
Old 07-13-2021, 10:07 AM
Carb, distributor, and heads sold.
