In the Hughes video he talks about Spragless creating a tremendous amount of heat on the street. Says will cook the tranny if driven too long. The 10 strut mechanical diode is where the strength is.
I suspect synthetic fluid is lower density than conventional mineral oil.
Wonder when higher density transmission fluid becomes a path to tuning and efficiency. |
I put JD Hyguard In mine to tighten it up slightly
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
The Following User Says Thank You to grandville455 For This Useful Post: | ||
I watched an in-car video of one of my passes, not the best video but it did catch the flash RPM and the shift recovery RPM. It currently ( with my previous 474 ) drops from 6600 to near 5200 on shift recovery. Is that a lot? Blaktopr ' only dropping a few hundred RPMs.
![]() Quote:
Vid of my playback tach. Engine made peak hp at 8000 and peak tq at 6700 https://youtube.com/shorts/zau289X213U?feature=share |
The Following User Says Thank You to slowbird For This Useful Post: | ||
900 normal ? Call it 1000 RPM.
No, its too much a drop. |
PTC told me that you will drop to the stall of the converter. There are variables that can change that, gear ratio (trans), shift point but it usually falls back to the stall. Now if you had a 5k stall and shifted at 10k, then odds are you will not fall back to stall. In my case i shift at 6500 and fall back to stall. If i wanted to, i can shift at 7k and still fall back to 6300, which would pretty much be a 700 drop, shifting 500 past peak hp. There seems to be no "blanket" number here. This is why guys tweak to get the best they can for heads up. Best possible fin angle/stator aggressiveness etc for best use of power. But IMO, taking what a company like ptc gives you is gonna run 90 to 95% right off the bat and can use a slight tweak after you compile data at end of year. There will be no "unicorn" converter combo that the internet will beat over a PTC or other known companies. In a case like mine, i need to run the number over and over wether its 10.0, 9.50, 6.0 or just any dial i choose for that weekend. Im probably too loose with a little excessive slip up top (also due to reduced mph from spragless messing up the calcs), and will pull it for a winter freshen. But i wont expect more than .1 if any when i get back to the track. I also dont need it.
The Following User Says Thank You to blaktopr For This Useful Post: | ||
Scott, looking at your dyno sheet my 2 cents is, 5800-6000 stall would be good. You want the engine rpm upstairs where your engine is making the most power. Also, run a converter with a sprag in it. They are faster.
I run a spragless Hughes converter with my throttle stop combo. Yes, it’s slower but imo it’s more consistent with the throttle stop,and has on avg about 14%-16% slippage on the top end according to my racepack. Mine flashes to 6300 and my engine made peak at 7100 and crosses at 7500ish. On the return road after a pass trans temp is at 150 and once the car is turned off the trans temp climbs to 175 but cools off rather fast when I put a fan on the trans pan/converter.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23 |
![]() Quote:
So how many times have you shifted your engine @ 8000 + RPM? Stan
![]() Quote:
My 2 cents GT. |
