Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Closed Thread |
#241
I got my new blower I installed to take some measurement (for the snout/imput shaft) then i removed blower and intake, took head off to replace the head gasket. Seems like there is always something!
GTO George |
#242
Well everything is together and I started it up.......sounded pretty good! Tomorrow I’ll put some heat in the engine so I can retorque the heads Sunday.!
GTO George |
#243
Hi George! Is your new blower a so-called "retro" style- with all the output going through a pie-shaped opening near the front?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#244
![]() Quote:
GTO George |
#245
Getting ready for the Quick 8 Memorial weekend!
Thirsty engine! My once a year oil change! ![]() |
#246
Well kids after 14 years of beating up my heads I finally decided to replace them! Got a new set from KRE and can’t wait to start beating these heads up! LOL!
GTO George |
#247
New castings………!
GTO George |
#248
High Ports? Shouldered washers in head bolt holes?
#249
Yes and yes.
GTO George |
#250
Heads are on and torqued! Damn it’s warm out!!!
GTO George |
#251
We’re you wearing your fire suit?
" Darksiders Rule "
#252
Damn……silly me!
GTO George |
#253
Looks like I’ll be firing it up tomorrow, just a couple of things to tweak yet!
GTO George |
#254
We’ll gang it’s been a long month but I finally got my engine started yesterday! I tweeted a few things today and it sounds awesome!
I like to give a BIG Thanks to KRE FOR ALL their help…..they are FANTASTIC!! I can’t wait for next weekend at Norwalk for the Blue Suede Cruise!!!! GTO George |
#255
Before i loaded my car yesterday i had to install my updated (NEW) safety harness. I normally ue RJS but I couldn't get them so I got the RCI......bad decision, I couldn't use the seat belts I ran out of adjustment when tightening them. The adjusters are 6 inches from the metal ends, my RJS are next to the metal ends. So I had to put my old seat belts in with the new harness and submarine belt. also the metal ends on the harness are backwards/upside down so I had to switch them!! I did get the car loaded by 10:30pm.
GTO George |
#256
I had the same problem with the RCI harness, but finally got it all sorted out.
Good luck this weekend. It's too hot here now to even think of moving. Getting old, I guess. ![]() Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#257
![]() Quote:
GTO George |
#258
I be mad 2 passes down the 1/4 mile….. still playing with the tune ( trying to creep up on the combo).I lost some compression with the new head (my other heads were cut a few times). Best has been a 8.12 BUT I’m only running a 49 top pulley (normal I run a 47 top pulley).
My next pass I will change to the 47 pulley…..I need to run a 8.05 or quicker to stand a chance in eliminations tomorrow. On a good note I did get my bump box finally working…..right now it’s bumping 6” at a time. The staging beams are 7” apart so it should be just right. The idea is to bump in as deep as possible without turning off the tip bulb. GTO George |
#259
So you need to stage as far forward as possible to make up for a slow reaction time. While at the same time increase your et and lowering your MPH. lol
Stan
#260
ET & MPH are just numbers, same as boost. It’s winning the round that really matters.
" Darksiders Rule "
Closed Thread |
