Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Closed Thread |
#301
![]() Quote:
Stan
#302
![]() Quote:
![]() GTO George |
#303
I got my car back together and started it up……sounded pretty good, hopefully everything will be ok at Norwalk. Should be loading it up Monday!
![]() GTO George |
#304
Well my car didnt get loaded Monday........had an issue with the delay box (it wasn't working). So the "Chinese Fire drill" we had to get my Bump box working last time at the track we did something to mess with my delay box..............soooooooo I took me a while to get it working (actually it was the two step). I did get it loaded on tuesday so hopefully everything will be fine for my first pass on Friday!
GTO George |
#305
All packed!
GTO George |
#306
Good luck, George.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#307
As of right now it seems my plug melting problem is a timing issue. I started pulling timing out one at a time till the plugs stopped melting…..it took a total of 3 degrees! I made 5 passes in al today all between 8.09-8.10 in the process I took 3rd place in the gamblers race…..go figure!! LOL!
GTO George |
#308
![]() Quote:
This is with your old blower setup on? I think you need lot more fuel still. New bigger, badder carbs maybe? (better still injection ![]() ![]()
#309
![]() Quote:
GTO George |
#310
Congratulations on your finishes George!
Thanks for stopping by.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#311
![]() Quote:
GTO George |
#312
![]() Quote:
GTO George |
#313
George,
OK you changed a number of parts and had a problem burning plugs. You made the wrong assumption that it was the new blower and changed back to your old blower and still had the plug burning problem. Now forced to look elsewhere you found the engine did not like the same time as before you change parts. So now, before you just throw / fling some more new parts at it. Put the new blower back on and tune the engine to it and see what the car will do. Stan
#314
![]() Quote:
GTO George |
#315
So basically im looking into another blower intake for my car (anyone have one)? I plan to do some kind of upgrade in the fuel department (i have no idea). It wont be easy because i run Nostalgia races.........they don't allow electronic fuel injection........soooo! I also need it to start without a second person...its a Bracket car!
GTO George |
#316
![]() Quote:
Thanks for now having some data that says you have a fuel problem. And it probably is not the fuel pump. 200 rpm and you fall off the cliff says you have a fuel restriction someplace that is fine at the lower rpm but when you add 200 engine rpm, you have a restriction in the fuel system. Think I said that a while back, as did several others on the board including Jim. I just agreed with what they posted in the past so don't come after me for agreeing with their initial assessments. Tom V.
#317
George, with the higher flowing heads it would probably use at least 100lb/hr more fuel. (don't know your specs and not figuring in blower)
If the fuel pump is not capable of keeping up with the increased fuel demand, that would be a problem. If the carbs are not capable of keeping up with the fuel demand that would be a problem. Then also if the intake can't keep up with the extra mixture, that would also be a problem. Then the new bigger blower would be even a lot more of a demand. Now if all are not capable, WOW. Plus using alcohol it would make a huge demand on the system. Gasoline may be OK, but it takes a lot of alky to run. ![]()
#318
![]() Quote:
GTO George |
#319
![]() Quote:
..........and i still made the KRE Quick 16 finals!!! ![]() GTO George |
#320
When you raised the RPM and it burnt the plugs again.
Did anyone read the plugs? Or are you just assuming it is the fuel system. Have you or anyone that can help you ever run a mechanical fuel injection system? I believe they have systems today you can add to make them one person start. It sure was not that way back in the 70's when I help a friend tune a N/A Hilborne injected 426 Hemi. Stan PS Also with as many runs as you have made burning plugs. Have you done a leak down test on those cylinders?
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 08-03-2021 at 03:13 PM. |
Closed Thread |
