73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 08-25-2021, 10:49 PM
75GrandLemans 75GrandLemans is offline
Default Blower motor issues 75 Grand lemans
PO ran a wire from battery with a toggle switch for the blower motor so I’ve been trying to get the fan switch in the dash to work. Replaced the blower motor, resistor, high speed relay, and the ac-vent-defrost switch. (Ordered a fan switch and that came instead)
Also made sure the ground was good on motor.
On the fan switch there is a spade on the bottom that is not hooked up to anything. Couldn’t find any wire that looked like it would plug into it. Tried grounding it and blew the fuse only on the high setting.
If anyone knows what is supposed to be hooked up there that would be great
Old 08-26-2021, 10:31 AM
sport coupe sport coupe is offline
Sounds like you have your wires crossed. Heater diagram should help finding the missing wire and proper color coded wire connections.
Name:	heater diagram 1975.jpg
Old 08-26-2021, 11:30 AM
What does I/P Reinf and HTR CONT mean?
Old 08-26-2021, 07:45 PM
Have 12 volts going to the hvac panel on the dash. Does anyone know where the ground is supposed to hook up to it? I’ve got the wiring diagrams but they don’t show that
Old 08-26-2021, 07:59 PM
Looks like the control panel is grounded on AH & G body?
(from a screw in panel to dash metal?)
Usually the fan motor housing is the ground.
Have a picture of the fan switch?
Old 08-27-2021, 12:42 AM
Well it’s got a ground on the motor but yep according to the service manual it’s supposed to have one to the panel. Thing is I can’t find that ground wire or where I could attach it on the panel. I do have a picture but don’t know how to post it.
Also if anyone would know where I can get the fan switch that’d be great. No luck at all the local parts stores and on the internet so far.
Old 08-27-2021, 05:57 PM
Have 10.5 volts at the blower motor hook up but it still will not run. Will run with 11 volts from the temporary wire from positive on battery
