Old 08-27-2021, 09:46 PM
MUSLCAH MUSLCAH is offline
Default Water pump Question
Is there a way to tell if my water pump is the original one to the motor ? 1967 GTO….and also ,who is the go to guy for having my water pump rebuilt ? And Thanks ? It does have the cast impeller.
Old 08-27-2021, 09:55 PM
OG68 OG68 is offline
The Dutchman.
http://www.fdrbp.com
Old 08-28-2021, 08:05 AM
nashcar nashcar is offline
Arthur Gould Rebuilders in Mass. is also good.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 08-28-2021, 11:08 AM
Might put up a picture of your "original" '67 8 bolt wp.
Of note, date codes did not begin til mid '67 production year.
Last, in rebuilding original water pumps for owners, you'd be surprised how many folks have given me decades old replacement casting pumps with cast impellers thinking that the pump was original.
Old 08-29-2021, 12:00 PM
Here’s some pics of my old pump....Can anyone tell me if it’s the original water pump to the car ....1967 GTO...and Thanks !
Old 08-29-2021, 07:17 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Friend of mine has a 67 and he was asking the same thing, I will ask him what he found out and let you know.
Old 08-29-2021, 07:18 PM
Thanks Rob !
Old 08-29-2021, 07:37 PM
indymanjoe's Avatar
The waterpumpman Is in bloomfield hills Mi has done a few for me and some friends.you get back your water pump with new seals properly clearance impellar i have 20k on my rebuild from him..My puter wont let me post a link..
I am the Thread Killer!
Old 08-29-2021, 10:47 PM
MUSLCAH, while the pump pictured does have a cast impeller, it is an early aftermarket pump housing without the correct raised casting numbers.
When was your '67 built?
Old 08-29-2021, 11:49 PM
Nov 66
Old 08-30-2021, 12:09 AM
Will check original 8 bolt wp castings. that early, it will not have a casting date.
Old 08-30-2021, 12:18 AM
Much thanks for that !
Old 08-30-2021, 05:39 PM
Here is the original Distributor out of the original motor 6 K 27. I am not a numbers guru...but is that like October ‘66 ......?
Old 08-30-2021, 06:42 PM
Sent ya a PM.
Old 09-02-2021, 09:15 PM
Longs's Avatar
Longs Longs is offline
My '67 was 14 years old when I purchased it, I don't know if it had the original water pump at that point or not, but I did replace it early on. I found a reference that the correct casting number is 9782482, which is the number on my pump, but it is date-coded B128, indicating February 12, 1968. I'm assuming that so long ago, when you got a replacement pump, wherever I got it at the time, rebuilt Pontiac water pumps were widely sold.
