Old 09-21-2021, 02:47 PM
ed boersma's Avatar
ed boersma ed boersma is offline
Default 4L80E Transmission hookup
How do I hook up the neutral safety switch and the backup lights to a 4L80E transmission?
Going into a '63 Catalina with column shift.
Thanks!
Old 09-22-2021, 07:00 AM
punkin punkin is offline
I've got an after market floor shifter and there are two switches integrated (reverse and neutral). I simply connected the factory wiring to these two switches. If you have a column car, there should be a switch package mounted to the steering column that gives you the same. If you don't have a shifter with switches for park & neutral, you can get a switch pack that mounts directly to the transmission.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
1969 Firebird
350/TH350
Mostly stock
2.56:1 Rear
The Following User Says Thank You to punkin For This Useful Post:
Old 09-22-2021, 10:09 AM
ed boersma's Avatar
Default 4L80E
The switch on the column under the dash has a different pattern (Slim Jim) than the 'E.
Who makes something that mounts to the Trans?
I expect that in the original installation the black box on the side of the trans is what handles the job.
Thanks!
Old 09-22-2021, 10:58 AM
Sirrotica's Avatar
Ed, here's a link to amazon harness and an OEM style GM PRND321 switch, this is how GM put a switch on the drives side selector shaft.
There are wiring schematics online that should get you the color coding to wire a OEM style switch into your car. I hope this is helpful.....
The switch from early hydramatic transmissions, to the T 400 in 65 might get you a switch that would interchange to the earlier column and give you the correct positioning for park neutral, and reverse for a later car might also be an option, but not having tried that, it would just be theory on my part.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-25-2021, 11:10 PM
ed boersma's Avatar
Default 4L80E
I've found some schematics but don't understand what leads I need to connect to the chassis harness for the neutral safety switch and the back up lights.
Thanks for any help!
