Old 10-02-2021, 12:15 PM
GMCM76 GMCM76 is offline
Default Grand Prix vinyl top opinion
Need to buy a new vinyl top for my 70 grand prix. Who has the best one??
Old 10-02-2021, 02:49 PM
padgett's Avatar
padgett padgett is offline
I always thought they were rust traps.
Web Site
Old 10-02-2021, 09:47 PM
U47 U47 is offline
Not if they were put on correctly Shijune001. My 69 still has it's original. You just need to take care of them.
Old 10-03-2021, 11:17 AM
I appreciate the opinions but still need some thoughts on who has the best and most correct reproduction vinyl top
Old 10-03-2021, 11:38 AM
SMS in Oregon is the best, uses NOS material. Slow service though and make sure the position of the seams below the back window is done at the right place.
Old 10-03-2021, 09:46 PM
hawkins69 hawkins69 is offline
Second the SMS. I’ve got interior upholstery, and vinyl top on order. Ordered Feb and hope to have by December. It’s pricey but it’s correct
Old 10-03-2021, 10:14 PM
scottydl scottydl is offline
Is NOS like that better than having a replacement top custom made at an upholstery shop?
And I’m curious to know the ballpark of “pricey” in this situation…
Old 10-03-2021, 11:06 PM
Is is best option out there if you’re looking for originality. The material is NOS- same that was used at factory. SMS has original patterns and dimensions for exact car as far as seams, so should be correct. My vinyl top for a 69 Bonneville was $495. I’m sure some upholstery shops could get it very close to original appearance for less $$.
The Following User Says Thank You to hawkins69 For This Useful Post:
Old 10-04-2021, 02:11 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Any good upholstery shop can do this, the real problem is if they care to get the seams right like the factory did it if that matters to you. Most replacement tops from years ago were just one giant piece or seamed up the middle, the factory tops had 2 seams, one on each side. Not a big deal on a driver when these cars were 5-10 years old, but on a high dollar restoration it's obvious to see when done wrong.
And yes, SMS will get you the right material the factory used. Just make sure you paint and seal that roof before you put one back on!!!
Old 10-04-2021, 03:26 PM
Stuart's Avatar
Stuart Stuart is offline
It may be worth doing a little legwork...check around for reputable auto upholstery shops in your area (you haven't included your location in your signatur, so unfortunately no one here can provide recommendations) and visit them to talk about your situation. Have them show you a sample of the material they would use, ask about the seams, etc., and then get an estimate of the cost.
Old 10-08-2021, 02:13 AM
todden8 todden8 is offline
Try to check out newstalgiaparts also. They offer replacement ones.
