Old 09-30-2021, 03:17 PM
duke455's Avatar
duke455 duke455 is offline
Default 73 Formula lower A arm bushing question
I've seen there are two different sizes on the lower bushings ...any way to tell what they are before taking it apart? Thanks
Old 09-30-2021, 03:55 PM
NOT A TA NOT A TA is offline
Put a wrench on the bolt head. 3/4" wrench for a 1/2" dia bolt and 13/16" for the 9/16" dia bolt.
John Paige
Lab-14.com
Old 09-30-2021, 04:37 PM
duke455's Avatar
I'm sorry I was talking about the bushing itself..I'll still look any what size yhe bolt is..it may help
Old 09-30-2021, 04:39 PM
duke455's Avatar
The heads of the bolts are actually 7/8"
Old 10-01-2021, 09:30 AM
78w72 78w72 is offline
the 2 different size bushings on the lowers should be front & rear location on the arm. very easy to tell which is which as they only go in one way. if that is what youre referring to for the different sizes.
the bolts should be the same size for both bushings.
Old 10-01-2021, 09:41 AM
Formulabruce's Avatar
Bushings are sized by the ID. the OD is the same.
Frame holes are 1/ 2" till about end of October, then 9/16"
So if a 3/4" wrench fits the bolt, you have the older, smaller style which is 1/2" . If a 7/8" wrench fits, you have the 9/16" bolt, which is the bigger and most common 73 style.
Old 10-11-2021, 09:29 AM
duke455's Avatar
Default Bushing
Ok..thanks for the info
I have the 7/8 " bolt head so what size would that bushing be ? Just wanted to order stuff before I have it apart..thanks again
Old 10-11-2021, 02:20 PM
I think I will Quote myself, from the post JUST BEFORE yours..
QUOTE > Formulabruce post # 6 >" If a 7/8" wrench fits, you have the 9/16" bolt, which is the bigger and most common 73 style. "
Since the Bushings are all the same OUTSIDE DIAMETER
They are sized by the INSIDE Diameter.
IF you really don't understand, order bushings for a 1974 Camaro or Firebird., or 75, or 77.... all the same.
Old 10-11-2021, 06:21 PM
duke455's Avatar
Default Bushing
Lol..I do understand
Maybe I miss read the part on the using itself being the same size..thanks
The Following User Says Thank You to duke455 For This Useful Post:
