Old 10-17-2021, 10:40 AM
61-63 61-63 is offline
Default notches at the top of the cylinders on Pontiac blocks
This has probably been covered before but why did Pontiac do this? And if you sleeve a cylinder you lose the notch so do you need to take a die grinder or sanding tube and recut it and if so why?
Remember, there are no dumb questions.
Old 10-17-2021, 10:49 AM
tom s tom s is offline
valve shrouding.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 10-17-2021, 02:28 PM
So it is only to help the engine breathe and not to prevent the valves from kissing the upper edge of the cylinder wall?
Old 10-17-2021, 02:59 PM
valve shrouding.Tom
The valves need to have an area completely around the intake valve to have FULL intake flow capability with the fixed bore diameter of some blocks. You could bore the crap out of the block (if the walls allowed it), (they will not), and not need the intake bore chamfers.
The valve diameter/valve angle is one concern with valve to piston and valve to block interference. Low lifts on the cam, not a real problem. Smaller valve diameter like the 1.96 diameter valves, not an issue. 2.11" and 2.15 inch valves and maybe the valve is MAYBE too close to the block. It depends on the camshaft lift and duration and the combination of parts..
A edge of the valve diameter is the closest it comes to the edge of the block in one area. But the flow has to get around that restricted opening therefore the valve chamfers are sometimes needed. Hope this helps. Stock builds probably no issues as
the factory offered some engines with no mods to the block for chamfers.
Old 10-17-2021, 03:01 PM
400 Lemans's Avatar
https://forums.maxperformanceinc.com...linder+notches
Old 10-18-2021, 01:05 AM
Dragncar Dragncar is offline
The 69 350 block was notched. 69 was the year they made the 350HP rated 350 with 48 heads. I understood they needed the notch to run those 2.11 valve 65.5 cc heads.
I ended up putting some 48s on a low mile 2 barrel 350 I had with those notches. Ran great with 2801 cam. Scrapped the block and wish I had not.
Old 10-18-2021, 09:37 AM
Shiny Shiny is offline
Assuming the notches were to improve flow it seems odd the 1970 350 with #11 heads had such large notches. These are low-compression small-valve heads so the notches were unlikely related to performance. Maybe emissions?
I think I read they were ~6cc volume, which helped explain the low CR on top of the large chamber volume (~88 cc?).
I copied this from another thread:
Name:	1970 Firebird pontiac 350 CI.jpg
Old 10-18-2021, 10:32 AM
If you want to talk about Emissions and how to lower emissions, there are a lot of theories on how to do that. Maybe start a different thread on that topic.
There are always exceptions to any concept.
One manufacturer got into trouble for Lean Burn strategies.
Most think lean burn is the right direction to go UNTIL YOU BLOW THE NOx EMISSIONS
which are caused by lean burn being too lean.
Companies were just trying to figure out emissions in 1970.
Most would say that a chamfer on the intake valve side is there for better flow.
Chamfers on both sides of a block would say, the engineers are doing something else in the combustion strategy.
Old 10-18-2021, 01:44 PM
Thanks Tom
Didn't want to talk about emissions, was just curious about other reasons for notches and the 70 350 was an example.
As you say, it may have had something to do with modifying the combustion process ... but seems an odd decision to spend the money machining a low-CR, low-performance 350 block and remains a curiosity for me.
I saw many product design decisions driven by marketing and/or regulatory requirements so maybe those are also possibilities. For example, maybe they just needed to reduce the CR to keep HP under some goal? They advertised 8.8 CR but it wasn't even close...
But I'm not curious enough to start another thread and likely would add no value for most.
Old 10-19-2021, 06:54 AM
Fine with me. Did the job for 7 years, no desire to go down that road again as a topic.
Maybe Keith Seymore could provide some insight as he was working for GM in the 70s.
And he did work in the Engineering side as well as the Plant side of the process.
Old 10-19-2021, 07:20 AM
steve25 steve25 is online now
Since chamfers where machined in accordance to valve inclination angles used such implementation could only be seen in regards to flow improvement’s because nowadays we know of better places to unshroud chamber’s in regards to just flat out improving emissions.
I can view it no other way!
Old 10-19-2021, 08:49 AM
Jay S's Avatar
Jay S Jay S is offline
I have been intrigued by this topic too. Looked for a pattern over the years and it is hard to follow. It seems largely to do with the combustion chamber shape of the heads, there may be multiple reasons. Not sure if the inclination angle was a driver, but it certainly effected the shape of the chamber.
I recall Steve25 flow testing the chamfer on a head maybe last year and it pickup up cfm at .100” lift and below, but IRC didn’t show much up at higher lifts. The later heads had narrower chambers and did away with the chamfers. My 2 bbl and 4 bbl 71 455 blocks I have do not have chamfers. Being that I haven’t seen every block made, I don’t know which blocks had bore chamfers and which didn’t. But the 68-70 blocks have the bore chamfer the same as the photo below with the chamfers higher. It seems largely do to the width of the chamber shape in the head. After 71 the chamfers became less and less common. Sometime in the mid 70s the 350s received chamfer on the exhaust only, which is unique, all the other engines had them in the intake or both. I thought I had a handle on what they did until I noticed exhaust only chamfers. It seems more like the chamfers are to unshroud certain combustion chamber shapes.
Here are some photos. If you notice these are both 1967 blocks xxxx133 castings and one block has the chamfered much lower. Both on the intakes.
The oily photo is from a 75 350, exhaust chamfers only with no valve reliefs. The other 2 are 67 400s.
ID:	575534   Click image for larger version
ID:	575536   Click image for larger version
Old 10-19-2021, 09:47 AM
Did 455s with their larger bore even need them?Tom
Old 10-19-2021, 10:05 AM
Jay S's Avatar
That is kind of the question that goes through my mind to Tom. I know I have seen bore chamfers on the 1970 455 in GTOs, and have seen them on the 71 455 HO. So apparently Pontiac thought they needed them. But on my 71 455 4bbl which originated in a Grand Prix SJ 455, it doesn’t have them. I assume that the round ports must have wider chambers than my d port engine. I don’t think they are worth adding if the engine doesn’t have them in most circumstances, especially on the 455 or over bore 400.
Old 10-19-2021, 10:14 AM
Pure speculation- maybe the 70 350 blocks were just a "carry-over" from a late decision to adapt to un-leaded fuel and drop the 4bbl/big-valve 350?
Were the notches in the 69 350 blocks the same size as those in the 70?
Old 10-19-2021, 10:43 AM
Jay S's Avatar
From what I have seen the 350s all had the same or very similar bore chamfers from 68-72. I Checked the cc’s once on a 71, seems like it measured in 3-4 cc for both sides.
Interesting to note also that the 67 blocks I posted pictures of the one with lower chamfers like you would see in a 66 389 4bbl, it was the code WW, or a 335 HP 4 speed. But the other photo with the chamfers higher was a WZ 325Hp Firebird engine. Both should have had 670 heads.
Old 10-19-2021, 11:30 AM
Here's a cast iron Termites eye view of how a .030" over 350 Bore looks like with no chamfer.
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 10-19-2021, 12:12 PM
Originally Posted by 400 Lemans View Post
Here's a photo of a 69 350HO posted by GRX in the thread linked by 400 Lemans:
The notches in the 70 350 block look the same to me, so I'm still speculating they were just a carry-over in 1970 without adding value.
Name:	69 350HO Double Notches.jpg
Old 10-19-2021, 12:53 PM
SD455DJ SD455DJ is offline
Jay, Interesting topic...and, agreed, confusing too. I never noticed the intake chamfers on this '71 455HO WL block.
Dennis
Old 10-19-2021, 03:58 PM
In late 66 and early 67 the factory likely machined a lot of the production 400 blocks with the lower set chamfers since those blocks could also get fitted with the 143 or 142 casting head which was still a 20 degree 389/421 type head or the very short lived 061 casting with the new 14 degree valve inclination angle.
Does anyone know if the 400 blocks fitted with the 061 casting still used the 389/ 421 type piston?
