Old 11-01-2021, 12:13 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Look for stainless band clamps in your area, comes in different diameters. Good for lap joints, ( Slip together joints). easily removable. They may be more
expensive than conventional exhaust clamps but they don't crush the pipe. https://www.summitracing.com/parts/sum-681300
just for visual purpose.
64 Lemans hardtop
4spd, buckets
  #582
Old 11-01-2021, 07:58 AM
gtospieg gtospieg is offline
X2 on those clamps...if you ever need to take it apart...and you never know, so plan ahead.
  #583
Old 11-02-2021, 05:06 AM
64speed's Avatar
64speed 64speed is offline
Any tips on getting the best fit and getting it tucked up as far off the road as possible
  #584
Old 11-02-2021, 07:39 AM
grivera's Avatar
grivera grivera is offline
You are better off putting it in place with band clamps and taking it to a good exhaust shop to have final fitting. This way while it's on the rack you can pin point how you want it and it's only a couple hours labor- well worth it. At the same time you can have the bung for EFI welded in.
Will Rivera
  #585
Old 11-02-2021, 07:44 AM
64speed's Avatar
The bung for the EFI is welded in. I guess I will plan on putting it on here and then dragging it up to the muffler shop for a nip/tuck. I do not like the pipes straight out the back. I planned to have them “adjusted” anyway. Anybody got some good pics of exhaust turn out placement?
  #586
Old 11-02-2021, 11:17 AM
I believe that Pypes sells a "high tuck" system, if you haven't already purchased your exhaust.
  #587
Old 11-02-2021, 11:55 AM
AG's Avatar
AG AG is offline
I've used the high tuck system and it fits well without hanging down.
  #588
Old 11-02-2021, 12:24 PM
grivera's Avatar
Does the high tuck system include an xpipe?
Will Rivera
  #589
Old 11-02-2021, 12:53 PM
64speed's Avatar
I called the high tuck is not available in 3 inch which I already have my kit anyway.
  #590
Old 11-07-2021, 10:52 PM
64speed's Avatar
Completed assembly
  #591
Old 11-10-2021, 11:11 PM
64speed's Avatar
Does anyone actually have the Pypes kit and can tell me or better yet show a picture of how the tail pipes look
  #592
Old 11-11-2021, 08:09 AM
grivera's Avatar
Is this the kit you have? https://pypesexhaust.com/i-12200886-...s-sga13ss.html
If so, looks like the pipes go straight back
Will Rivera
  #593
Old 11-11-2021, 06:22 PM
I can tell you this...the tailpipes will be pretty close to the rear tire(depending on tire width and wheel backspace.) with the 3" exhaust. I have 2 1/2" and 255's and it's kinda close...
  #594
Old 11-11-2021, 07:40 PM
64speed's Avatar
I think I’m gonna mount it all up then of course go to the exhaust shop and get it all tweaked
  #595
Old 11-12-2021, 02:25 AM
NeighborsComplaint's Avatar
Leave your tailpipes off and take it to a muffler shop to re-route the tailpipes to side exit behind the rear wheel with factory splitters. They can probably rotate the downtube behind the rear axle and reweld it. That would look a lot better than straight out the back or turned down.
Triple Black 1971 GTO
  #596
Old 11-13-2021, 01:38 PM
64speed's Avatar
The final video
https://youtu.be/Y-mlAsRfLK8
  #597
Old 11-13-2021, 01:51 PM
ZeGermanHam's Avatar
Looks amazing.
1998 BMW 328is (track rat)
  #598
Old 11-13-2021, 02:31 PM
grivera's Avatar
Unbelievable job they did on your car! Wish you the best with it and look forward to the drivetrain portion!
Will Rivera
  #599
Old 11-13-2021, 04:40 PM
64speed's Avatar
I knew this was a gamble but unless it blows up in my face between now and Friday choosing KMA to do this work was the best decision of this build so far. They are in Tampa and I am in SC. 8 1/2 hours away. The owner sent me pics or talked to me EVERYDAY. I don’t care if you live in Oregon, if you need it done ship it to him. 50 dollars an hour labor rate. You cannot beat it.
  #600
Old 11-19-2021, 06:51 AM
64speed's Avatar
This is it. This is the day! Heading to Florida to get her
