Old 11-23-2021, 10:32 PM
racerboy's Avatar
racerboy racerboy is offline
I was originally thinking about running the ‘stump puller’ from SD Performance, but here is the cam that Butler recommended for my car (4-spd with 3.55 gears)
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
  #142
Old 11-24-2021, 12:47 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Originally Posted by racerboy View Post
Thanks Mark. Do you only run your car on 93? It’s not a big deal to me, but I didn’t realize that there wasn’t more of a safety margin with the aluminum heads. I would probably run a hydraulic roller cam as well. The guys at Butler sent me over a recommendation. I’ll post that later.
Hi, Yes only 93; it's not a daily driver. The Wawa near by just started selling 91, might try that at some point just to see.
65 Tempest, 400, TH400
86 Fiero SE 2.8
  #143
Old 11-24-2021, 09:33 PM
racerboy's Avatar
Ok thanks. I have no problem with running the 93 octane, I guess I was just a little surprised that I would need it.
