Old 09-19-2021, 11:59 PM
blueghoast's Avatar
[QUOTE=johnta1;6280917]That's a good MPH. Probably low 10's in quarter.
Was he running slicks?
We are hoping for a low ten sec pass and yes he was running slicks.
They don't prep the track where he was at to make it more like the street.
It was hot and humid real bad that day, He said every body was having
problems and there times were down from usuall.
GT
  #102
Old 09-20-2021, 10:05 AM
Murf Murf is offline
Originally Posted by grandam1979 View Post
The engine is a 1970 455 + .060 good rods and pistons stock crank with the SM heads cam is a comp hydraulic roller .520/.540 236/242 113ls. I did use solid rollers I had on shelf. Intake is a SM Black Friday single plain I made match heads. Personally I would consider this engine a street engine at 10.7 and the little cam. Carb was the weak link this weekend I used a 800 spreadbore holley I had on shelf also. Probably not my greatest idea but I had it so I used it. Hopefully we will take it to the Pontiac race at Bunker Hill in two weeks with a improved carb setup.
Nice results! Do you happen to know the weight ? What trans, converter & rear gear?
Murf
  #103
Old 09-20-2021, 03:13 PM
About 3250# P/G 3.89 gear
  #104
Old 09-20-2021, 03:14 PM
Thanks!
  #105
Old 09-25-2021, 02:38 AM
Brian Baker's Avatar
Getting close to that time...will there be another Columbus Day sale?
  #106
Old 09-25-2021, 12:13 PM
I’m waiting till Black Friday to get mine.
  #107
Old 11-25-2021, 11:33 PM
Any Black Friday sales this year?
  #108
Old 11-26-2021, 06:17 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
https://www.speedmaster79.com/Pontia...-Cylinder-Head
$1200.....
  #109
Old 11-26-2021, 02:12 PM
gobrdgo gobrdgo is offline
I got mine. Couldn’t resist.
  #110
Old 11-26-2021, 03:50 PM
nachomax's Avatar
nachomax nachomax is offline
Originally Posted by 67Fbird View Post
Thank you for posting this!
  #111
Old 11-26-2021, 06:23 PM
Jack P. Jack P. is offline
https://www.amazon.com/Speedmaster-P.../dp/B07GLNGJ78
Are these the same as other Speedmaster head deals?
  #112
Old 11-26-2021, 06:29 PM
I believe it’s the same head but it’s a bare head. On the Speedmaster site they have valves & springs, I think,
Murf
  #113
Old 11-27-2021, 12:57 AM
Nobuddy Nobuddy is offline
Bare heads are $488 each on speedmaster79.com during the sale.
  #114
Old 11-27-2021, 01:21 AM
I see on Speedmaster79.com that complete heads are $1193. My question for people that bought them last time at this good deal and used them, do they work good? What I mean is were they flat and assembled correctly and usable out of the box? When it comes to parts like this I wonder if buying the bare heads and having a good local shop prep them and be sure they are perfect is maybe the better way.
  #115
Old 11-27-2021, 01:35 AM
I went ahead and ordered mine bare. There’s a YouTube video easy to search where someone breaks down a set and critiques them.
  #116
Old 11-27-2021, 02:02 AM
Sirrotica's Avatar
Here's the link to the review:
https://www.youtube.com/watch?v=fFfPEjG0uCc
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #117
Old 11-27-2021, 09:58 AM
mysticmissle's Avatar
i just finished building a 30 over 400 with speed masters from last years black friday sale, and a good size hydraulic roller from Randy Repp. Installation was easy, quality seems good. motor sounds great We elected not to port match the cnc ridge at this time, as we have a 300 hp bottom end with a 500 hp top end, and did not want to disassemble the heads for power we did not need. it sounds amazing, idles well, no smoke or leaks from the heads, it has a torker 2 the head port size is in slightly smaller than the big edelbrock gasket and slightly larger than stock torker 2 size. make sure you order guide plates too, and i would order a set of head studs or bolts asap so you dont have to wait
if you can live with chinese heads on your pontiac and you are not trying to make the earth rotate backwards with pontiac power, they are hard to beat for my two cents. we are expecting deep 12s or better in an original muncie backed 1970 lemans street car. he is moving up from the stock 350 2 barrel, it should be fun. i just ordered another set to have instock
The Following User Says Thank You to mysticmissle For This Useful Post:
  #118
Old 11-27-2021, 10:13 AM
We are well into the 10’s with a out of the box set.
  #119
Old 11-27-2021, 12:45 PM
69FIREBIRD76MM's Avatar
I just. Bought me a set and a couple of my other buddies too..
  #120
Old 11-27-2021, 01:15 PM
Do these heads have a horsepower limit? Where do they top out at when working with them, not doing a lot of welding and trying to make them something they are not. Wondering about this as built and/or with some porting and larger valves? Trying to decide to buy bare or complete. Going to put them on a 455 block but thinking ahead because of the price, don't have a motor plan yet.
