I have to admit, I wouldn't mind a little more power. Right now I have a bone stock RAIII. If I rebuilt it with a stroker kit, keep the #12 heads, use dish pistons to reduce the CR to around 9.5:1 to make it pump gas friendly what would I be looking at for power with let's say a 744 cam? Would that be the best choice or some other cam or other options? I'd like to get 450-500 HP.
curious to see what others suggest on this, but with stock heads & a smaller cam like that (224/236 ~.406 lift), is 450-500hp even possible? especially if you are using a stock intake & exhaust manifolds.
The Following User Says Thank You to 78w72 For This Useful Post: | ||
I guess that's really my question, what's the most HP I can get with stock heads, 9.5:1 CR and stock exhaust manifolds? I figured the heads would need porting and probably a bigger cam. I asked Butler the same question so we'll see what they say.
This is what Butler said:
"With stock heads and a stroker bottom end and a hyd. roller about 420-430HP is it (with a good intake and an 850cfm carb and headers) That’s about as far as you can push with pump gas and no additional air flow. The same combo with either a well ported iron head or an out of the box alum would make 500+HP" This is the cam they suggested: Butler/Comp SP Street Performance Billet Roller Cam (HR) 288/294, 236/242, .521/.540, 112 LS I don't know if the experts here will agree with that or not. But, based on that with my planned setup (stock intake, no headers) maybe close to 450? That would probably be worth it.
well im far from an "expert" but it sounds like stock heads & ex manifolds would kill any real advantage of doing a stroker... for about the same money you could probably get the same or more power with a set of aluminum D port heads & a roller cam & some ram air manifolds??
The Following 2 Users Say Thank You to 78w72 For This Useful Post: | ||
![]() Quote:
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share Last edited by jhein; 11-30-2021 at 04:23 PM. |
BTW, when I used the word "expert" I was not taking a jab at you at all. I appreciate all advice, and pretty much everyone here knows more than me anyway.
![]() Quote:
i didnt take it as a jab at all, just wanted to state up front im far from an expert compared to some on here but have been dealing with pontiacs/firebirds & doing most of my own work on them for 30+ years. but i will leave it to others to provide more suggestions & knowledge on this. |
HP is misleading, even more so when dealing with motors that make much more torque than HP. People often throw away a lot of lower RPM TQ to gain a little of upper RPM HP.
What do you want the car to DO? I've built higher compression, ported head motors that ran in the 11's. But they were not that much to just drive around. My current motor is a low compression (8.3:1) 455, stock crappy "66" heads (huge chambers, pressed-in rocker studs), and an old P4B intake manifold. The cam is a 222/242 @ .050", low lift (.443"/.435") on a 116lsa that is happy with the stock rockers, pushrods and adjusting nuts. The cam is sort of modern version of the 744, optimized for a motor with a better exhaust system. I DO have a low-restriction exhaust, and it also has a FAST efi/ignition control system - but a well tuned HEI and Q-jet should perform just as well. The car has a 3.08 gear, a THM 350 with a stock converter, runs great on the cheapest gas I can find, and tends to run cool. It puts 316hp/385tq to the wheels. I took it to the track recently. The trans was shifting several hundred RPM too late, and I had to launch at part throttle to keep from spinning, but it still ran 13.20. I just got some parts to address the transmission issue, and hope to do more track testing soon. https://i.imgur.com/P0pUNqX.mp4
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
The Following 3 Users Say Thank You to Lee For This Useful Post: | ||
![]() Quote:
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet Th400 gone. Tkx close ratio with .64 of 66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque ![]() ![]() |
The Following User Says Thank You to 66beaumont For This Useful Post: | ||
That's the SD performance cam? I know you said stock heads, but just to confirm, no porting?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share Last edited by jhein; 12-01-2021 at 03:38 PM. |
Jhein
It looks like you and I are looking to do the exact same thing. My ‘70 RA Iii has less than 10k miles on it, but when the previous owner had it rebuilt on 2009, the shop he went to re-used the stock rods and some lo-performance 8-eyebrow pistons. They also put in a cam smaller than an 068. Since I was going to pull the engine to address these issues, I had a couple of threads running about whether I should stroke the original WS 400 or drop in a 428 I have in my garage. I ultimately decided to find a 400 or 455 block, and go the stroker route with a set of aluminum heads and one of the SD Perf. cams. I’ll just bubble wrap the original block and #12 heads for now. I’ll be curious to see what you ultimately wind up doing with your combo.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
![]() Quote:
![]() Quote:
The biggest problem I have right now is finding someone to build it. I want to do it this spring. All the big name people are a year or more out. I'm looking around now for someone local but nothing yet.
Jhein & Racerboy,
I don’t know if this will help you, but here it goes. A few years ago, I purchased a 1970 T/A that had a service replacement block. The person I bought from had the engine rebuilt and replaced the #12 heads with RA IV #614 heads. After I bought the car, the engine had to be rebuilt with less than 100 miles on it. I decided to have the engine rebuilt with a 427 stroker kit and with the .030 overbore now have a 433 CID engine. The engine was dyn’d but I only got uncorrected numbers. 447 HP @ 5000 RPM and 535 TQ @ 3500 RPM. I figure the corrected numbers are 460 HP and 545 TQ. Compression is 9.9 to 1. All of this runs thru the oversized RAIV manifolds. My engine builder thinks long tube headers would add 30 HP. Hope this helps. Last edited by napster; 12-02-2021 at 12:35 PM. |
![]() Quote:
Butler custom grind.
Yes SD cam(first version) and no porting. A jet upgraded by myself with parts from Cliff. Have not yet had a chance to get to drag strip
jhein,
I also have a 461 stroker in a '78. Running e-heads and long tube headers and an off the shelve comp cam XR288HR. 583HP @5500 and 623TQ @ 4200. 9.5 to 1 compression. This might help more than the other example. |
![]() Quote:
How do you use that car and how are it's manners?
