57 Hydramatic Shifting
My Star Chief shifts into 4th gear about 20-25 MPH. Is this normal? If not, how can I make the shifts at greater MPH, other than using the shift lever to manually shift? Thanks for the replies.
At light throttle that's a normal 3-4 shift.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
Thanks, that makes me feel better. Guess I just need to put my foot into it a little more!
Adjusting your linkage (kickdown) will help longer runout.
Hope this helps. GT |
They should shift at around 8, 15 & 22 MPH on a light acceleration.
The difference between inlaws and outlaws? Outlaws are wanted |
Is that the rod from the carb?
Yes. Shorten it about 1/16" of an inch and try it.
Thanks.
Jim K in PA 1967 GP HT 428 1967 GP convert 428 1957 Chieftain 4D HT |
In retrospect, I probably should have named it differently, pontiacsafari.com makes people think it is about safaris but it is about all 1955-57 Pontiacs and some later years. |
