Old 01-05-2022, 07:19 PM
JSuchma JSuchma is offline
If you don't like the counter sunk situation, just use a longer bolt and washer to cover it up. Won't look exact, but a casual glance won't know the difference. Heck, as we all know, the originals were not made for 65 and up heads either. The hard part is done, so thanks to everyone involved! Just do what you have to do to make it work for your specific need. This ride has been amazing so far. The next intake in line should be the D19088 RAV tunnel ram. Hello Tom
  #402
Old 01-05-2022, 07:30 PM
tom s tom s is offline
NFW Jeff!One of these in a lifetime is enough for me.Sounds like a good project for you!John might be able to not counter sink the holes on a special order basis.Send him a PM.Tom
  #403
Old 01-05-2022, 07:38 PM
Maybe he should get a count of who doesn't want the holes counter sunk.
  #404
Old 01-05-2022, 07:39 PM
tempest1964's Avatar
On a CNC machine it would be a very easy fix. After spot drilling and then drilling the thru hole for the bolts John would just have to skip the counter bore tool in the program. As Tom said, just contact John. Should be easy peasy.
  #405
Old 01-05-2022, 07:46 PM
Jeff,the program is set up in the machine.My vote is to leave as it was intended from the scan of the Bill Blair intake and IF John wants to do special orders thats up to him.Tom
  #406
Old 01-05-2022, 07:48 PM
Gotcha!!!!!
  #407
Old 01-05-2022, 07:50 PM
I’ve been a CNC machinist for 42 years. It is no big deal to skip a tool. It does not require changing the program.
  #408
Old 01-05-2022, 09:15 PM
Guys,the reason we counter sunk is because of after a ton of hours trying to figure out how to fit the intake under a hood without cutting the hood I found I had to put a short spacer under the rear carb to clear the intake bolt.Also had to use 5in top AFBs and marine air cleaners with 1/4 cut off to fit under the hood of a 62 GP.Unless you want to put the intake on a bench and admire it I would suggest you get a intake with counter sunk bolts.I have a pic of the problem but cant seem to post pics from my phone anymore.I cant text the pic to someone to try to post it for me.Send me a text to 5622430570.tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #409
Old 01-05-2022, 09:49 PM
Pic
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #410
Old 01-05-2022, 09:50 PM
Finally got it to post from my IPad!
  #411
Old 01-05-2022, 10:25 PM
beemergary's Avatar
Originally Posted by 61-63 View Post
I don't like it either but it is easy to fix just turn some aluminum sleeves down and insert them in the counter sunk holes and then run hex bolts through them. I want the intakes I ordered anyway.
You beat me to above post. I'll probably do the hex bolts but then again to be honest its a reproduction and the many mopar and few ford and chebby guys ain't goinna know the difference. If there's a machine change I am in but if not carry on guys.
  #412
Old 01-05-2022, 11:01 PM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Either way works for me. Can’t wait !!
it’s the suspense that kills me. -Wile E Coyote
  #413
Old 01-06-2022, 06:44 AM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
It's counterbore. NOT countersink. One guy knows the difference. ^^^
Easy fix as already stated. Either by skipping CNC steps or by making some sleeves, etc.
Name:	Counterbore and Countersink Pic.jpg
  #414
Old 01-06-2022, 06:55 AM
JSchmitz's Avatar
If you had them skip the counterbores, it's easy to add them later using a piloted counterboring tool, vertical mill, etc.
  #415
Old 01-06-2022, 08:49 AM
sdbob sdbob is offline
Tom I'll trust your judgement and experience. All I want for Christmas 2022 is ....
  #416
Old 01-06-2022, 10:51 AM
mgarblik mgarblik is offline
That's the same tooling I use on the aluminum heads destined for race engines. That tooling can cut a nice counterbore for step washers that eliminate crushing the aluminum around the head studs. Not needed of course in this application with the light clamp load. The manifold top looks great. Just can't wait for the finished product. Personally, I don't care how you finish the fastener attachment area. I can make it look the way I want after the fact. Question though: Could some of the SD guys chime in concerning painting these manifolds or leaving them as=cast aluminum? What did most people do back in the day these were raced? I have many pics of the bathtubs. Some painted, some raw aluminum. Not sure what would look best, most correct? My engine will be almost all blue. Blue SD style valve covers with stacks. No chrome. Thanks for the input.
  #417
Old 01-06-2022, 10:53 AM
Guy,IMO your making a big deal out of nothing!How many people except for the 40 or so on this thread have even seen a original?A Zajack repop,a Williams repop?There is a nice Zajack repop for sale on this site for the guys that want a early intake with no counters BORES!The inside of this intake is NOTHING like a original or a Zjack repop either!Tom
  #418
Old 01-06-2022, 11:00 AM
Sirrotica's Avatar
Reminds me of a saying that my father used to say:
"You'd argue with St Peter, about the way he opened the gates of heaven, before you came in"..............
Have a nice day Y'all...........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #419
Old 01-06-2022, 11:04 AM
Mike Davis's Avatar
No issue with the Counterbores here.
Tom, what type if throttle cable bracket have you used with these that you feel is best?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #420
Old 01-06-2022, 11:40 AM
61-63 61-63 is offline
Mike like you I have lots of pictures of bathubs plus have restored two real ones plus have handled ?? 50-60 54299/91 and 9770859 inline intakes. Both bathtubs and more than 90% of the inlines were as cast aluminum with no evidence of paint ever having been on them. IMO they look best as bare aluminum. That is just me.
