Old 01-12-2022, 06:05 PM
slowbird's Avatar
slowbird slowbird is offline
Was the T2 ported for a 4500 carb?
Any pics of it?
Old 01-12-2022, 06:15 PM
POS Racing POS Racing is offline
Any pics of it?
Not actually ported to a 4500 but with some grinding to open up an adapter I think it may really like one? It liked a 2" spacer with the 4150
ID:	581765   Click image for larger version
ID:	581766   Click image for larger version
Home of the 350 Pontiac that KICKED FULPER'S ASS!
Old 01-12-2022, 07:03 PM
darbikrash darbikrash is offline
I'm doing a 350P now, great to see your post. Can I ask a few questions? As-cast the KRE chambers are 65 cc, what size did you end up with after working the heads? Did you find you needed the block eyebrows with the small valves?
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 01-12-2022, 07:18 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
You topped the big blowhards 350 in power, well done.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
The Following User Says Thank You to 455Grandville For This Useful Post:
Old 01-12-2022, 07:19 PM
The heads as cast as delivered were actually 70cc. After my mods they were 77cc. I had them milled .100"(yes you read that correctly) and they landed at 62cc.
I did not need the notches for clearance....those valves would free drop down the bores... barely, but they did clear. But when I added the notches to the bore fixture it made a HUGE difference in airflow
The Following 3 Users Say Thank You to POS Racing For This Useful Post:
Old 01-12-2022, 07:28 PM
Thank you!
When I built my 1.0 version it made 385hp/425tq with 8.8comp, flat tappet cam and mildly ported iron heads I was pretty proud. Posted it on a FB group and he basically told me it was a joke and NO ONE would ever beat his "King 350". Challenge accepted!😎
Where I differ from him is I hope someone now realizes these little guys have potential and instead of scrapping one builds one better than this one. Pretty sure I could have topped 600 with this one but Mama told me it needed perfect street manners. Little cam made for a helluva torque curve though
The Following User Says Thank You to POS Racing For This Useful Post:
Old 01-12-2022, 08:36 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Very nice!
Old 01-12-2022, 11:11 PM
Seems the 3- Intakes are within measurement error. But my real point is to wonder which Intake promotes the best acceleration under load in the 1/4 mile.
Old 01-13-2022, 12:39 AM
Luckily they sure will be easy to check at the track!
Old 01-13-2022, 01:24 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by POS Racing View Post
... Recently had a set of KRE CNC chamber heads here and it was completely opposite....lost 15cfm by. 500 and kept getting worse from there. Same with the E heads I originally started the build with...
Who'da thunk?
Old 01-13-2022, 04:52 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Congrats and thanks for sharing your results.
Kris.
Old 01-13-2022, 09:21 AM
61-63 61-63 is offline
Very nice engine! Who needs a 421 etc. to make power?
The Following User Says Thank You to 61-63 For This Useful Post:
Old 01-13-2022, 11:29 AM
Sirrotica's Avatar
After watching Engine Masters within the last week on Motor Trend they had a NA 350 chevy that they dynoed, and you exceeded their numbers. When you're able to exceed the engine that has had more development time, and money thrown at it in the last 65 years, you have really done something well....
Nothing I like better than to see a chevy beaten by a Pontiac on an equal playing field. As long as your car hooks, your gonna break some hearts.....LOL
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-13-2022, 12:37 PM
charlie66's Avatar
How does a 350 block compare in strength to a 400 block? Does anyone know ?
Great numbers! Nice to see this ...
My Half AN Injun.....
Old 01-13-2022, 12:42 PM
carbking's Avatar
carbking carbking is offline
Great job!
Since this is the street forum, I hope you are better at traction control than I. First gear on mine (only 430 HP) is worthless on the street when driving in anger
Jon.
The Following User Says Thank You to carbking For This Useful Post:
Old 01-13-2022, 04:15 PM
steve25 steve25 is online now
While we are handing out over due applause for killer Pontiac 350 motors let’s go back to 1974 and Burt Straus and his Sunbird that I saw run a 8.85 in the 1/4 mile early that Summer.
It was well worth my two flat tires that I had to deal with to get to Englishtown and see that take place!
Old 01-13-2022, 04:26 PM
Rob Roy Rob Roy is offline
Nice work! Thanks for sharing.
  #38
Old 01-13-2022, 04:35 PM
Stan Weiss's Avatar
Steve,
I saw Burt at Englishtown also (not sure what year). While he had to run factor iron heads, most of the ports (intake and exhaust) were nowhere the factory location That is what could seen just looking at the engine. Have no idea what one might have seen looking at the head from the combustion chamber side.
Stan
Pontiac Pump Gas List
  #39
Old 01-13-2022, 04:50 PM
For years, Tom S. and I have been discussing WHY so many Pontiac guys dismiss the 350P. Tom has advocated for a stock stroke, stock rod length build using either the KRE or E-heads. This build SHOULD open eyes AND minds to the potential of the 350P when properly planned, engineered and built.
POS Racing, I’m going to assume you utilized an LS piston blank and ring pack with your pistons?
Dr. Thomas Sowell
  #40
Old 01-13-2022, 05:15 PM
Stan, I never got the chance to track him down in the pit’s to see the car.
As I recall a thunder storm rolled in and I headed home.
Is he still with us, does anyone know or has he passed?
